cornerweighting - roll-off pads, laser levelers
Old 06-06-2010, 12:48 PM
RX-Ben
RX-Ben's Avatar
Default cornerweighting - roll-off pads, laser levelers
I am thinking of welding up a set of roll-off pads b/c $900 seems ridiculous for a set of aluminum boxes.
Anyone have any suggestions on where to get the little screw-in leveling feet?
Also - is a laser leveling kit (like the $260 ART) required, or is it possible to get by with a $15 laser and some other procedure?
Thanks.
Old 06-06-2010, 01:16 PM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
I just shoot mine off a laser level from one pad, and adjust the other 3 to match
Old 06-06-2010, 01:19 PM
gkmccready
gkmccready's Avatar
Home Depot probably has screw-in feet... or MSC Direct?
Old 06-07-2010, 08:05 PM
Wren
Wren's Avatar
St. Jude Donor '03
You could definitely make your own. mcmaster-carr should have some feet you can put on. Our's uses all thread turned down to go in to some plastic feet.
don't waste your time with the laser levels. Use a water level, a machinist level, or a surveying transit.
Old 06-07-2010, 08:23 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
clear tubing. water. dye if you want and two clamps.
To cornerweighting - roll-off pads, laser levelers
Quick Reply: cornerweighting - roll-off pads, laser levelers
