Brake Caiper Seals, Where can I buy some?
I want to rebuild my Brake Calipers using the DRM stainless steel pistons. I need a new set of piston seals. GM only sells it as a kit that includes Pistons, Seals and Dust boots. $90 per caliper.
All I need is the rubber seals. Where can they be found?
Terminal Vette Addict
I just got my Kit with my DRM setup. ASK them it was like $39 per caliper i think?
You can also try gmpartshouse.com which gets anything GM pretty cheap
you cant get it except as a kit I think.
You arent doing the dust boots at the same time?
OEM calipers dont like dust. Esp after your pad is 50% or more gone
I would buy OEM seals, it is a kit so you will get the boots also. Boots will burn off fast so I would keep then if you sell the car or use them in the winter.
Nope. Not for the c4/5 at least. The only caliper parts kits I've found have the rubber boots that go on the caliper pins, and the clips for the pads. No seal kits, no caliper boots...
Napa, autozone, pepboys, advance auto, all nada
Part Number: CE143.62036Manufacturer Number: 143.62036
I just bought some SS calipers from another forum member here, mainly because they came with boots/seals (also I knew I'd want to make this upgrade).
That stock number is for the C5, sorry I'm so used to buying parts for my C5s I didn't even bother to look for the C4.
Just take out your o-rings and find some viton o-ring stock to replace them with. If you can't find any at a hardware or autoparts store, get on McMaster Carr and order the size you need.
I'm lucky in that respect, we have drawers full of o-rings where I work. We go through them like water in the mill.
I am trying to find the dust seals for a 2010 GS and I am told that there are non anywhere. Who is Gene Culley, anyone can help?? Thanks. I have the car in the air waiting for the calipers to be rebuilt..
thanks,
thanks,
