Is anybody selling used slicks in sizes for stock C5Z wheels?
Old 06-12-2010, 09:34 AM
tjZ06
tjZ06's Avatar
Default Is anybody selling used slicks in sizes for stock C5Z wheels?
I know it's a long shot (since nobody really runs 17s anymore) but does anybody out there have a slick appropriate for a ~3100lbs 600rwhp C5 Z06 using stock wheels (17x9.5 & 18x10.5 front/rear)? HPDE (20-25min sessions) only not full-fledged racing. I'm just looking for an economical tire to rip up at a few track days this summer.
Thanks,
TJ
Old 06-12-2010, 01:14 PM
eogel
eogel's Avatar
Are you looking for a real slick or something like a Hoosier A6? I am asking because I see posts referring to the A6 as a slick.
Old 06-12-2010, 01:25 PM
eogel
eogel's Avatar
Here is what I have. Shipping is from Raleigh, NC 27612. Pay via PayPal.
Hoosier slicks, Quantity of 2
Heat Cycles: 0
My Price: make offer
List Price: $413
Markings: DP60, U8F5, sticker still on one but writing is worn off, both have same usage.
17” Hoosier A6, Quantity of 2
Size: 335/35-17 (weighs 28.0 lbs for shipping; dimensions are 25x13.75x25)
Mfg Wk/Yr: 3807
Heat Cycles: 2
My Price: $90 each
List Price: $314
Old 06-12-2010, 06:20 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
there is a very limited supply of used, nearly new, scrubs from Pro race teams in 17" sizes. Nobody runs them any more.
Old 06-12-2010, 08:48 PM
Han Solo
Han Solo's Avatar
I imagine some of the National guys running Solo 2 in SS class would still be selling off tires a couple of times per year. I think most of them are running Hoosier A6s, 295/17 in front and 315/18 in rear on stock C5Z size wheels.
Try the SCCA Forums.
Old 06-13-2010, 10:19 PM
fatbillybob
fatbillybob's Avatar
I got 2 hoosier A6 295x17 for the fronts $100 for both
1 set 4 hoosier A6 315x 17 $150 bucks
2 new yokohama slicks 280 650 18 that can be run front or rear
These are about 400each but I'll sell the pair for 400.
fatbillybob@yahoo.com
Old 06-14-2010, 04:55 PM
AlwaysInBoost
AlwaysInBoost's Avatar
I have 4 - 285/30/18 Hoosier R6's with only 3 heat cycles and tons of tread left, I'm in PA though...
Old 06-14-2010, 11:44 PM
tjZ06
tjZ06's Avatar
I was hoping to find true slicks. If not A6s or 710s will do (not really interested in R6s after doing more research, everybody says the A6s are better/faster and last just as long).
fatbillybob I'll email you about those front A6s.
Thanks,
TJ
Old 06-15-2010, 12:27 AM
yakisoba
yakisoba's Avatar
Hard to find. I run 17" still because of weight, but not scrubs anymore. Too bad, it's a decent size if you run stock brakes.
Old 06-15-2010, 04:28 AM
tjZ06
tjZ06's Avatar
Yeah, I have LG GStops so I can still run stock C5Z front wheels. If I run C5Z rear wheels on the front I have to run a little spacer, which pushes the wheel/tire out too far (it will contact the top of the fender under compression, and under full-lock it'll hit the fender at the back of the wheel opening).
I also have a TON of stock C5Z wheels so I really don't want to change.
-TJ
Old 06-15-2010, 02:09 PM
kwhiteside
kwhiteside's Avatar
Thanks,
TJ
I've got some v710's
pair of 275/17's $100 half tread
pair of 335/17's $150 great tread
older rubber but stored and has ran good for me.
Also a set of 17's as follows
Fronts, Z06 17X9.5 with V710 275's 60% tread
Rears, C4 ZR1 17X11 with V710 315's 60% tread
the Zr1 wheels work great on the C5 and will mount up the 335's just fine. Make offer if interested but shipping will probably kill on wheels/tires together.
Old 06-16-2010, 07:23 AM
tjZ06
tjZ06's Avatar
Just to be clear my back rims are also stock C5Z wheels and are 18" (18x10.5") so I still need 18s out back, just 17s up front.
kwhiteside I'll PM you...
-TJ
Old 07-04-2010, 08:43 AM
tjZ06
tjZ06's Avatar
I got some front A6s from fatbillybob, so I'm still looking for 315/30-18 A6s for the rear C5Z 18x10.5 wheels.
-TJ
Old 07-04-2010, 12:05 PM
Sidney004
Sidney004's Avatar
Did you try John Berget and Bob Chick yet? Good luck.
http://www.jbracingtires.net/
Bob Chick:
Phone: 843-762-7324
or Email: usdrctrs@aol.com
To Is anybody selling used slicks in sizes for stock C5Z wheels?
Quick Reply: Is anybody selling used slicks in sizes for stock C5Z wheels?
