Oil Leak after CMP
Old 06-12-2010, 06:12 PM
RaleighSS
RaleighSS's Avatar
Default Oil Leak after CMP
So did my post track inspection today and found the bottom of my motor to be covered in oil. I did not notice this when I changed the oil the day before the event. I do not notice a loss of oil in the crankcase. Few Questions / Facts.
Checked the Oil Cooler lines and fittings all look OK ...
Oil Seems to be coming from front of Motor
All photos taken from bottom of car
See Oil at motor side of water neck ... seems very wet there.
If I over filled the crankcase where would the oil go I thought it would just blow more into the intake and burn it off... It is possible that I put too much en when I went a quart over ... (not probable but possible)
Any thoughts would be great...
Old 06-12-2010, 07:02 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
front seal
Old 06-12-2010, 09:05 PM
waddisme
Support Corvetteforum!
waddisme's Avatar
Do you still have original crank pulley? I think something happens to the oem rubber over time and they wobble and then there is a seal issue. Does yours wobble?
Old 06-12-2010, 09:44 PM
RaleighSS
RaleighSS's Avatar
Yes it is original will get under there tomorrow and see if I see any wobble. If it is that seal does the motor have to come out to fix?
Old 06-12-2010, 10:42 PM
drivinhard
drivinhard's Avatar
rad fan
steering rack
front pulley
water pump
front cover
good time to put in a cam
Old 06-12-2010, 11:09 PM
waddisme
waddisme's Avatar
If you think there is ever a chance you might do cam, now is a good time, or if later, then put the 2 piece front cover on. Will save a lot of time later!
Old 06-12-2010, 11:36 PM
GettReal
GettReal's Avatar
Did you pull off the intake to see how much oil you might have in there?
Old 06-12-2010, 11:40 PM
sperkins
sperkins's Avatar
Mine looks exactly like that after every event.
I just clean it off and race it again.
And some folks call me crazy.
Old 06-13-2010, 08:14 AM
Kanmer
Kanmer's Avatar
Cruise-In VI Veteran
It can come out of the intake or it can even be PS fluid. These are notorious for leaking PS fluid. I have run mine and have that happen every time.
Bob
Old 06-13-2010, 08:50 AM
Falcon
Falcon's Avatar
Squirt some Grease Lightning on it and see if it turns purple. In my experience, if I squirt GL on Mobile 1 it turns purple. That could help identify the fluid.
It could be p/s fluid, which as Bob says, gets every where.
Old 06-13-2010, 09:13 AM
varkwso
varkwso's Avatar
PS fluid or oil from front seal is prime canidates as stated....
If it can clean up...run it again like Scott!
Old 06-13-2010, 11:00 AM
ssdeuce
ssdeuce's Avatar
Mine started doing that at my last track day. Pull your coupler on the throttle body and see if you have oil standing there. Mine was pushing oil out the coupler going to the air filter.
Old 06-13-2010, 06:35 PM
RaleighSS
RaleighSS's Avatar
Cleaned it all up (before the grease lightning tip) looked in the intake and did see some oil as well as some in the air bridge... Just gonna have to monitor it. This ls6 has 65k on the clock of which about 8k are from the track other than valve guides this is the only issue she has had.
Old 06-13-2010, 09:48 PM
ssdeuce
ssdeuce's Avatar
Here is the thread I started. Sounds like the same is going on with yours.
http://forums.corvetteforum.com/auto...of-intake.html
Old 06-13-2010, 11:01 PM
FredSM
FredSM's Avatar
Originally Posted by John Shiels
front seal
Yep, my guess too. Mine is in the shop right now getting its 3rd balancer. Two have failed (OEM and after-market) and the front main seal is a target for the AC belt if it gives way. First lost oil catastrophically . . . second looked like the OPs pics . . . slow, stinky leak.
FM
Old 06-14-2010, 02:20 PM
RaleighSS
RaleighSS's Avatar
FM
how would I know balancer is bad? would it move or make noise?
Old 06-15-2010, 04:42 PM
2K3Z06
2K3Z06's Avatar
Location: KADS- If it has wings or an engine, I can break it. Dallas TX
track cars that run high oil temps. (280+) are hard on seals, the oil can handle 300 degrees but the seals start leaking like crazy..........
To Oil Leak after CMP
Old 06-15-2010, 05:55 PM
John Shiels
Even running hydraulic equipment like a rough terrain forklift or backhoe when the hydraulic oil runs hot the seals on the machine really have a short service life.
I like all the people here saying the oil handles the temps except your motor is not made of oil.
Old 06-15-2010, 05:59 PM
John Shiels
The oil looks like it is spread every under the motor and not favoring one side like power steering does in my experience. I doubt it is the intake either. Keep up posted. How much oil do you use?
Old 06-16-2010, 09:46 AM
FredSM
FredSM's Avatar
My tuner said the OEM balancer would wobble by hand. GM techs confirmed and replaced it under warranty . . . but not before the small AC belt flew apart and wrapped itself around and damaged the front main seal, dumping a ton of oil in the paddock and putting my car on the trailer. My 2nd balancer (after-market) has now failed. The pulley began to separate from the balancer and created an offset with the accessory pullies, which began to fray the main belt. What finally caught my attention were the drops of oil at the track a couple of weeks back. My undercarriage looked exactly like your pics and the car was still driveable, although the AC belt was gone again. Probably gave way and damaged the main seal again, just not as badly. I'm not sure if a failing balancer alone can damage or cause seepage around the main seal, but a wobbly balancer is not good.
BTW, OEM balancers are a little hard to come by right now, probably for more than one reason.
FM
Quick Reply: Oil Leak after CMP
