NASCAR Alignment
Old 06-18-2010, 07:10 PM
gkmccready
gkmccready's Avatar
Default NASCAR Alignment
So, I was watching practice at Infineon on SPEED earlier... they said that a bunch of the cars are running maximum negative camber to get better bite. Now here's the bit that shocked me: -8 degrees. (!!)
Old 06-18-2010, 08:04 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
That must really look kicked in hat type of cars?
Old 06-18-2010, 08:06 PM
Joe_Planet
Joe_Planet's Avatar
they should just do 90 degrees so they can just ride the wall
flink
flink's Avatar
v8 supercars...
They look to be around -6 to my eye.
It is pretty odd. AFAIK there's nothing unusual about the front suspension. wikipedia sez "Basic front-suspension configuration is double wishbone (made compulsory for both makes through Project Blueprint), whilst rear suspension is a "live axle" design, using 4 longitudinal links and Watt's linkage for lateral location."
Old 06-18-2010, 11:16 PM
efranzen
efranzen's Avatar
How about the Milliken MX1 with 45° of camber?!
Old 06-19-2010, 07:39 AM
John Shiels
dumb me I SEE NASCAR now for type
Old 06-19-2010, 07:41 AM
Solofast
Solofast's Avatar
NASCAR uses tall 15 inch tires and the compounds have improved a lot over the years, so there's a lot of lateral force going into a tall tire. That equals a lot of deflection which means big negative camber. Remember too, while they are running radials, there are big differences in construction and if the tire has more bias type of construction that will equate to needing more negative camber. Taken as a whole it all makes sense....
Old 06-19-2010, 11:25 AM
rfn026
rfn026's Avatar
All that negative camber makes the tire companies crazy. I'm just amazed at how much negative camber you need (can use) with the new tires.
Richard Newton
Facebook
Old 06-21-2010, 07:31 PM
2000BSME
2000BSME's Avatar
that's not 45* though.
Old 06-21-2010, 07:36 PM
2000BSME
2000BSME's Avatar
Originally Posted by flink
v8 supercars...
that can't be true either. The rear wheels have camber in them also.
Old 06-21-2010, 09:00 PM
trackboss
trackboss's Avatar
It is very true. Those cars have very trick live axles with bolt on uprights that can be set for camber.
Old 06-21-2010, 09:44 PM
2000BSME
2000BSME's Avatar
Old 06-22-2010, 03:11 AM
trackboss
trackboss's Avatar
The V8 super cars are amazing. Crazy fast considering how many restrictions they have. The teams however have huge budgets. Think about $125k for a top motor and the front running teams having 8 motors with two dedicated on the dyno for research.
There is a great book about them called insiders guide to v8 supercars 2006, or something like that. Lots of detailed info and photos which only makes one wonder how wild the stuff is they won't show.
Old 06-22-2010, 05:08 AM
flink
flink's Avatar
One of the aussie "GTO" guys went to an auction and took lots of photos of supercar parts. http://www.ls1gto.com/forums/showthread.php?t=255474 - lots of parts ****.
Motorsport's huge in .au. And none of this left-turn-only stuff
Old 06-22-2010, 06:40 AM
2000BSME
2000BSME's Avatar
I wonder what the 'water brake spray tank' is.
Old 06-22-2010, 07:00 AM
bosco022
bosco022's Avatar
My old GTA Monte Carlo had a -1.5* cambered axle quick change.
Worked well.
Harry Gant won four NASCAR races in row back in the early 90's.
Reportedly that was the first time a team used the cambered
rear axles. Positive camber on the left rear.
Old 06-22-2010, 10:57 AM
mgarfias
mgarfias's Avatar
Worked well.
Donohue/Penske were experimenting with it on the Trans-Am Javelin in the early 70s. As far as I remember they were just copying what the nascar guys were already doing.
To NASCAR Alignment
Old 06-22-2010, 11:34 AM
Solofast
Solofast's Avatar
Old trick of bending negative camber into the rear axle was often done on live axle road racing cars even before it was popular in NASCAR. AFAIK it was outlawed or restricted in NASCAR, It's tough on axles and bearings....
I had a friend who was going to do it to a C prepared autocross car, the shop that was going to do it apparently used chains and a lift... The shop owner said "you don't want to be around here when we do it, it's pretty ugly"... After seriously thinking aobut it he chickened out....
Old 06-22-2010, 11:38 AM
Solofast
Solofast's Avatar
Water is used to cool brakes in some series where it's allowed. The spray is shot into the center of the brake rotor and is turned to steam as it goes thru the vanes. Takes away a lot of heat and works well on heavy high powered cars.
Old 06-22-2010, 03:51 PM
trackboss
trackboss's Avatar
I have a cambered rear end in my race car. The aussie cars are nothing like that. They have a complete upright bolted on the end of the full floater and it is adjusted with shims. Very trick and I'm sure very expensive.
Quick Reply: NASCAR Alignment
