power steering fluid boil over
Old 06-28-2010, 07:02 PM
Dirk Miller
Dirk Miller's Avatar
Default power steering fluid boil over
Hey guys,
My ’08 C6 is not the Z51 version and l am having power steering boiling over issues. After changing to Red Line power steering fluid, I was hoping this would make a difference but it really has not helped. I notice the boil over only happens when I do HPDE road-course events. Once it cracked and GM did replace the reservoir. However I notice it is still overflowing.
I am thinking about hooking up a Z51 heat exchanger, but it looks so flimsly that I am wondering if I actually need something more substantial.
Anyone out there know of a couple different solutions I can try?
Old 06-28-2010, 08:59 PM
c4cruiser
c4cruiser's Avatar
Where is the fluid level when cold? When hot? You might try removing some fluid so that when the fluid is hot, the level in the reservoir is at the "Cold" mark.
If you don't have a PS fluid cooler, it sounds like you should add one. Doesn't necessarily have to be a GM cooler, Perma-Cool makes a two pass and a 4-pass cooler that will work. Fluid coming from the return line should flow into the cooler and then out to the reservoir.
Old 06-28-2010, 09:18 PM
froggy47
froggy47's Avatar
Originally Posted by Dirk Miller
Hey guys,
You need the Turn One p/s pump. It's not boiling, it's over pressured.
Old 06-29-2010, 12:48 AM
Dirk Miller
Thanks Bob,
I will look into this
Old 06-29-2010, 01:18 AM
Cloaked323
Support Corvetteforum!
Cloaked323's Avatar
Check the fluid cold it's probably too high mine was. I then switched to redline but it was overfilled again. Although it was overfilled, it didn't boil over as much. I drained some out it's just above the cold line I'll see the results at Laguna Seca in a couple of weeks. I did buy a turn one just in case due to a stock pump failure.
Old 06-29-2010, 06:18 AM
naschmitz
naschmitz's Avatar
I have the same problem with my 2006 base coupe. I bought a Turn One pump and some synthetic PS fluid but haven't installed it yet. The Turn One pump is less than $200.
Old 06-29-2010, 07:16 AM
johninar
johninar's Avatar
I thought the power steering had a pressure relief valve to prevent over pressurization? Am I wrong, or if not, why doesn't it work?
TIA,
John
Old 06-29-2010, 07:32 AM
ipuig
ipuig's Avatar
St. Jude Donor '09
Hey guys,
A cooler does help, I used a small plate style cooler I bought from Pegasus Auto Racing Supplies and mounted it where the Z51 or Z06 cooler would go.
The reservoir is located on the return side of the rack and the suction side of the steering pump, so it should not be over-pressurizing from anything other than the higher vapor pressure of the fluid when at higher operating temps. Changing the steering pump will not solve the preceived over pressure in the reservoir. Lowering you fluid level can help by giving the fluid more room to expand once it heats up.
I'm still using the stock GM steering pump, so I cannot speak as to the durability and effectiveness of the turn 1 pump.
Old 06-29-2010, 12:24 PM
LEAVINU
LEAVINU's Avatar
Gotta love the forums. Never heard of this mod but have experienced some overflow myself. Not sure if its to much fluid or true boil over at this point but did find this in my Google search.
http://www.gmhightechperformance.com...all/index.html
Now the question is where do yo buy one? Any vendors on here?
Old 06-29-2010, 12:35 PM
drivinfast
drivinfast's Avatar
here is my install of the turnone. just google and you will find Jeff and the site. last pics for the larger PS cooler
http://forums.corvetteforum.com/c6-t...t-off-car.html
Old 06-29-2010, 12:59 PM
SIK02SS
SIK02SS's Avatar
Zip tie a rag over the top to absorb the excess fluids. The fluid will ruin electronic sensors on the car and cause more problems. Also a good fluid like Joe Gibbs is a good thing to switch to
Old 06-30-2010, 03:36 AM
Cloaked323
Cloaked323's Avatar
As I stated earlier I switched to "Redline" and lowered the fluid, I will see what happens next week
To power steering fluid boil over
Quick Reply: power steering fluid boil over
