315 30 18 a6 square setup
Old 06-28-2010, 10:56 PM
redazz
redazz's Avatar
Default 315 30 18 a6 square setup
is anyone running 315 30 18 a6's on c5 z06 10.5" wheels at all 4 corners on a c5? any rubbing issues? looking at changing my autox set-up
thanks
john
Old 06-28-2010, 11:04 PM
rasrboy
rasrboy's Avatar
thanks
john
Yep, just gotta watch lock to lock as they will rub.
Old 06-29-2010, 12:19 AM
thehammer69
thehammer69's Avatar
thanks
john
I was running that combo...fit fine but the front lower control arms had some light rubber marks on them from full lock turns in a parking lot.
The biggest issue I had was that the square setup made for a loose handling car. Great for tight Autocross courses where you need the car to rotate. BUT, that same looseness could be aggravating on fast big courses.
Old 06-30-2010, 05:26 PM
redazz
redazz's Avatar
thanks guys .looking at some other threads it looks like i might have clearence issues on my brake ducts if i go to 315's up front ,may just stick with 285's up front .
thanks again
john
Old 06-30-2010, 11:14 PM
fatbillybob
fatbillybob's Avatar
I run the hoosiers that way because too lazy to stock a bunch of wheels. rubs brake ducts a bit no big deal works fine on road course and it is not too loose to me.
To 315 30 18 a6 square setup
Quick Reply: 315 30 18 a6 square setup
