In Car Camera, whats a good one?
Old 07-01-2010, 05:33 PM
LeMans05C6
LeMans05C6's Avatar
Default In Car Camera, whats a good one?
I have been looking at the GoPro Hero HD Motorsport one that comes with all the mounts shoots in HD and handles at 32gb SD card. Looks pretty clear from the videos and for $300 it seems like a solid options.
Are there other good ones that I am missing, any good or bad reviews about the one mentioned above.
Would appreciate all the feeback i can get. I have a track day on the 17th-18th and would like to start videoing myself so i can review my own session and see what i can improve on.
All comments appreciated.
Thanks.
Old 07-01-2010, 05:35 PM
dfinke23
Support Corvetteforum!
dfinke23's Avatar
Old 07-01-2010, 06:31 PM
naschmitz
naschmitz's Avatar
I really like the Vio POV 1.5. Records in DVD quality but does not suffer from "jellyvision" that the GoPro and other CMOS cameras have. Also plugs into your cigarette lighter so you don't have to remember to charge batteries.
You can see a sample here: http://www.youtube.com/watch?v=0NwQSyH6DU8
http://www.vio-pov.com
Old 07-01-2010, 07:00 PM
RonnieM
RonnieM's Avatar
This is what I got. With a second battery it was 139. Just used it at VIR and it worked like a charm.
http://www.amazon.com/Aiptek-1080P-D...6041096&sr=1-3
Old 07-01-2010, 07:27 PM
LeMans05C6
LeMans05C6's Avatar
Nice video with the Vio POV, what do you mount that on so its right in the perfect place behind your head. Is there a bar that goes across behind the seats?
Old 07-01-2010, 07:31 PM
naschmitz
naschmitz's Avatar
I have it mounted to a harness bar, but the actual camera is much lighter than a camcorder so the mounting is much more flexible and easy. The recording unit resides in my center console along with the cigarette lighter plug for power.
Old 07-01-2010, 07:40 PM
LeMans05C6
LeMans05C6's Avatar
Those harness bars aren't cheap. If i am not going for a 5 pt harness yet, there really isn't a cheap way to mount a camera back there. I wonder about the GoPro's suction mount or what looks like a sticky dash mount. Trying not to go ALL out right now but would like video of my laps.
Old 07-01-2010, 07:51 PM
naschmitz
naschmitz's Avatar
The Vio POV comes with several sticky mounting options for flat surfaces, helmets, etc.
The beauty of the POV is that you can see exactly where it is aimed by using the monitor in the recording unit. I couldn't ever see exactly where my GoPro was pointed.
Old 07-01-2010, 08:50 PM
redrckt97
redrckt97's Avatar
looking for more info too..
I have a harness bar with flat plate camera mount - how does your camera mount? (my AZ Speed bar sits low so the mount needs to raise the camera up to see over the dash) Will a suction cup mount stuck on the harness bar plate work?
Old 07-01-2010, 09:58 PM
J.R.
J.R.'s Avatar
VIO POV 1.5 for me.
Had it for over one season in race car and it is still working (amazing).
Easy to use and you can see a screen to adjust lens.
I use a Longacre roll bar extension used to mount mirrors and it is very light and raises the lens about 6-8 in above harness or roll bar crossbrace.
You can also use an 8 GB SDHC card which should give you about 3 hrs at medium resolution.
Old 07-01-2010, 11:12 PM
Wayne O
CF Senior Member
Wayne O's Avatar
I leave my better Sony videocam at home and use an inexpensive "Flip Ultra" camera on the track. It works well enough for my purposes. Kodak has a camera very similar to the Flip videocam that I read some good reviews on.
Not long after the Go-Pro came out I checked out their website....the video taken through the camera looked like it was shot with a fish-eye lens. That turned me off of the Go-Pro. A friend recently bought a Go-Pro and said that isn't the case any more...the video looks 'normal' now.
Old 07-02-2010, 10:03 AM
LeMans05C6
LeMans05C6's Avatar
Well the GoPro got me intrigued because it didn't look like I need the crossbar to mount it in certain places.
Would it be a bad idea to use those adhesive mounts on the dash above the radio just right there in the front. not sure how the height would be?
Old 07-02-2010, 11:42 AM
jmorgan07z06
jmorgan07z06's Avatar
Flip Video Ultra or Kodak Zi8. The kodak has an external mic connection which is great and can accept a 32mb flash card.
Old 07-02-2010, 04:07 PM
bobmoore2
bobmoore2's Avatar
I hope you meant 32 billion Bytes (32GB), not 32 milli-bits (32mb).
Keep the comments coming folks. I'm also in the market for a video camera, so I'm all ears.
Old 07-02-2010, 05:58 PM
GreekPT
GreekPT's Avatar
I started a similar thread a while back re: Flip Vid vs Go Pro vs ??
http://forums.corvetteforum.com/auto...-feedback.html
Old 07-02-2010, 09:35 PM
Joe_Knesek
Joe_Knesek's Avatar
The GoPro is a battery hog (25 minutes) & the quality leaves a lot to be desired. I went through 2 of them before I found the VHoldR Contour HD. It runs for 3 hours on a charge & can be plugged into 12v aux. It also has 2 aiming lasers which is a big plus. The GoPro uses an optical viewfinder which unless you are a contortionist is useless when mounting it on the rollbar.
http://vholdr.com/contourhd/helmetcam
http://vholdr.com/node/73365
Old 07-04-2010, 12:41 AM
waddisme
waddisme's Avatar
It is what I use with the wide angle lense. Here is a quick vid:
http://www.youtube.com/watch?v=sSUzhPXKYTk
Less that $150 for camera, lense and 8g card.
To In Car Camera, whats a good one?
Old 07-04-2010, 01:32 AM
dfinke23
dfinke23's Avatar
What mount are you using?
Old 07-04-2010, 01:37 AM
Dirty Howie
Dirty Howie's Avatar
I plan on mounting mine there. Another member had video from this mounting location and it looked great !
I'm just worried about any damage to the dash from the adhesive tape
DH
Old 07-04-2010, 01:42 AM
Dirty Howie
The manual says it will get 2.5 hours I think (at least 2) too lazy to get up and find the box ......
Quick Reply: In Car Camera, whats a good one?
