Z06 Engine removal?
Old 07-05-2010, 06:23 PM
JDIllon
JDIllon's Avatar
Default Z06 Engine removal?
Any one remove the C6-Z06 engine from the top? I have a 4 post lift and want to remove a Z06 engine from the top. If you have or know someone that has please let me know I just need some advance advice. Jim Dillon 772 335 8318 home or PM or Email Thanks!!
Old 07-05-2010, 06:40 PM
cebars
cebars's Avatar
Yes, C5 Z06 PM sent.
Old 07-05-2010, 07:00 PM
varkwso
varkwso's Avatar
I have...
Old 07-05-2010, 07:51 PM
SouthernSon
Support Corvetteforum!
SouthernSon's Avatar
Location: Deal's Gap 2004 NCM Motorsports track supporter
Received 1,101 Likes on 715 Posts
Originally Posted by varkwso
I have...
He's AAAAAAALIVE! Missed you this past weekend at VIR, ole buddy. Saw Tim and company.
JD, why do you need to remove from the top? Need whole engine reworked or just partial? Drivetrain? May be more specifics could help some point you in a good direction. As Jeff said, he has probably removed engines top, bottom and each side. Of course, he has a very capable crew that helps out (sons).
Old 07-05-2010, 08:57 PM
JDIllon
JDIllon's Avatar
I ran for 3 days with the PCA event and the car ran great. On the first session of the NCM event when I came in the engine was making a squeaking sound from the left bank, it sounded like #3 valve spring, so I didn't run the rest of the event. When I got home and check under both valve covers there does not seem to be anything wrong. However after checking the oil filter, ther is filings in the filter and on both of the drain plugs. So I'm pretty sure that the engine is going to have to come out for a tear down. Will know more tomorrow. I only have a 4 post lift and I would like to pull the engine myself. Therefore it needs to come out the top. Any help would be welcome. JD
Old 07-05-2010, 09:18 PM
Falcon
Falcon's Avatar
JD, is that a Katech motor?
Old 07-05-2010, 09:23 PM
JDIllon
JDIllon's Avatar
Yep!
Old 07-05-2010, 09:47 PM
Timz06
Timz06's Avatar
Hi JD...sorry about your engine problems. I think it would be easier for you to pull the whole drivetrain out from the bottom. If not, you may have to pull the heads and accessories first so you can get it out of the car.
Tim
Old 07-05-2010, 09:54 PM
drivinhard
drivinhard's Avatar
pretty easy to pull it from the bottom w/ a 2 post, basically the reverse of how the car was built.
Old 07-05-2010, 10:08 PM
JDIllon
JDIllon's Avatar
Hey Guys!!!!!!!! I know the way to do it with a 2 post lift! The question is how to get it out the top with a 4 post lift????? Thanks, JD
Old 07-05-2010, 11:01 PM
sspeed30043
sspeed30043's Avatar
Crap, not to bum you out, squeaking noise is usually a spun bearing...
Old 07-06-2010, 12:33 AM
dvandentop
dvandentop's Avatar
Jim ya still need to get the torque tube/tranny/diff outta the way one could removed them and pull em outta the way then use a cherry picker to remove the motor from the top
car would be sitting on jackstands on the lift then most likely
Old 07-06-2010, 01:32 AM
dfinke23
dfinke23's Avatar
I've done it both ways, through the top is the way to go (it will come out in one piece).
Old 07-06-2010, 07:10 AM
dvandentop
dvandentop's Avatar
tranny diff and toruq tube also daniel? crazy would have to have a long shop to pull that one off prolly
Old 07-06-2010, 08:45 AM
varkwso
varkwso's Avatar
You have to loosen the cradle and you can leave the TT in place to take out the top. I do it with jackstands and cherry picker. cajunvette (sic?) has a good writeup with pics on his website
Old 07-06-2010, 09:11 AM
ajg1915
ajg1915's Avatar
St. Jude Donor '08
Basically, jack up the car on the (4) post using wood blocks under the jacking points (pucks).
Remove the hood, radiator, etc ... out of the way, disconnect and drain all of the fluids.
Disconnect all of the wirng, hoses, etc ... It helps to have a marker pen and ziplock baggies to mark and label the hardware as you go.
http://www.cajundude.com/engineswap.htm
Old 07-06-2010, 11:21 AM
JDIllon
JDIllon's Avatar
Great write up thanks Guys. I think that this is what I was looking for. Will let you know if I decide to do it myself? Going to talk to some local shops today. JD
To Z06 Engine removal?
Old 07-06-2010, 01:19 PM
dfinke23
dfinke23's Avatar
No, I meant you don't have to take off the heads to get it out, as was mentioned in an earlier post.
Old 07-06-2010, 02:26 PM
bowtiguy
bowtiguy's Avatar
Jim,
so sad to hear the news...
I had a squeak too in my 454 LS7. turned out to be a failing HS rocker arm(s). Doesn't help you with the drain plug metal parts though unless your Rockers ARE coming apart
For the record I paid about $2K to have the dealer R&R my motor the last 2 times.
If my motor has to come out again....I'm BUYING a 2 post lift ( to go with my 4 post in my third bay) and doing the R&R myself.
Old 07-06-2010, 02:30 PM
ajg1915
ajg1915's Avatar
St. Jude Donor '08
You could drop the motor out the bottom toby rolling a dolly underneath and using the engine hoist to hold it up while you remove the cradle.
I've done them both ways on my (4) post.
Sucks to have motor problems.
Originally Posted by bowtiguy
Jim,
Quick Reply: Z06 Engine removal?
