Rookie at miller in sept. What ratio?
Old 07-06-2010, 11:45 AM
az55
az55's Avatar
Default Rookie at miller in sept. What ratio?
I'm a rookie in ST2 and I've never run Miller. For the Nationals I'm considering changing from a 342 rear end to either 373 or 390.
I have a custom RPM trans with .85 5th gear. Should I stay with what I've got or make the change?
If you have experience at Miller, I would like to hear opinions. I am putting down 374 rwhp.
Cheers,
CV
Old 07-06-2010, 05:42 PM
L98Terror
L98Terror's Avatar
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
Stock gear ratios work fine for me at Miller
Old 07-06-2010, 05:54 PM
az55
az55's Avatar
They certainly worked for you last year!
Thanks for the reply. Good luck in September, I look forward to meeting you and all the Corvette guys at the Nationals.
Cheers,
CV
Old 07-06-2010, 07:17 PM
96CollectorSport
96CollectorSport's Avatar
Location: If you don't weigh in you don't wrestle Road America
If TTS counts we also had stock gears (3.42) and a MN6 box, we didn't even use 5th down that big **** strait.
Old 07-06-2010, 07:23 PM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
does your car have aero? how many revs?
M6 and 3.42 is pretty good as you have a nice 2-4 ratio spread and good gearing from 50 mph to 145 mph
posted some wanted traqmate data from any C5 or C6 at MMP but haven't found any yet.
Old 07-06-2010, 07:50 PM
kentz06
kentz06's Avatar
You might try talking to the folks at Pfadt since it is their home track.
Dean
Old 07-06-2010, 11:09 PM
96CollectorSport
Yes the car did have aero, sorry no data. We'll have to wait till this year, but we are running a G2X. Guess we'll have to wait for that.
Old 07-07-2010, 08:28 AM
L98Terror
L98Terror's Avatar
Correct, although it is a very long straight with the elevation you get a lot of power loss so it's no faster than the end of the back staight at Mid Ohio
To Rookie at miller in sept. What ratio?
Quick Reply: Rookie at miller in sept. What ratio?
