Best competiton tire beside Kumho Ecsta V710 and Hoosier a6
Old 07-14-2010, 01:16 PM
CStewTAMU
CStewTAMU's Avatar
Default Best competiton tire beside Kumho Ecsta V710 and Hoosier a6
I was planning on getting some Kumho Ecsta v710 275/40-17. Apparently there is a national backorder. The guy most our club member buy tires from called every supplier he knows and couldn't find any.
I am hessitant to get Hoosier a6's. I hear the A6's might be the fastest tire, but I also hear their performance diminishes faster over the life of the tire when compared to the V710.
I do want something I can get more laps out of as I do NCCC autocrosses due to the providing 4-5 times the numer of runs/track time compared to SCCA.
I think BF Goodrich makes a very similar competition tire. Anyone use those?
I do want a slick tire like the a6 or v710-not a street tire with tread.
Old 07-14-2010, 01:55 PM
RX7 KLR
RX7 KLR's Avatar
We run the R1 on one of our Club Racing cars, and have autocrossed on them as well. They are great on the track, stand up to abuse very well, and put down consistent lap times - the BFG R1 actually won two classes at the Runoffs last year.
However, as an autocross tire they are not great. They take to long to heat up, and even at its peak will be about a second off the pace of the V710 or A6.
Old 07-14-2010, 01:58 PM
trapp
trapp's Avatar
The V710's are on backorder or the Kumho XS's???
Old 07-14-2010, 02:26 PM
RX7 KLR
RX7 KLR's Avatar
It seems pretty clear from his title, and text, that he is talking about the V710. There is no mention of the XS in his post at all.
Old 07-14-2010, 03:08 PM
trapp
trapp's Avatar
I just checked.......both are backorder nation wide. I heard the XS were backorder thats why I asked..
Old 07-14-2010, 04:22 PM
BFoster
BFoster's Avatar
Does anyone know the reason why the V710's are backordered? I tried to order a set two months ago, and Tirerack said it would be at LEAST 12 weeks before they would get them back in stock...
I prefer the Kumhos to the Hoosiers, even though they are just a hair slower.
I was HOPING that Kumho just let the supply of V710s go, and have built a new, faster tire that they are preparing to roll out.
Old 07-14-2010, 05:56 PM
jaa1992
jaa1992's Avatar
Location: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps GA
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
I've been running the R6 in time trials, seems to be as sticky as my ancient v710's were.
Not sure if it helps you on an autocross.
Old 07-14-2010, 05:57 PM
0Finspeed
Former Vendor
Finspeed's Avatar
Take a look at these, they are in stock and ready to ship.
http://www.finspeed.com/Michelin-Racing-Slicks-MCH.htm
Compared to the A6's, you will not be disappointed.
Old 07-14-2010, 06:45 PM
Sidney004
Sidney004's Avatar
Kumho has been struggling financially as of lately and that may have something to do with it.
Old 07-14-2010, 08:40 PM
Lan.Jet
Lan.Jet's Avatar
What is the life compared to the A6's I usually get two days.
Old 07-14-2010, 10:11 PM
NASCAR314
NASCAR314's Avatar
Try the Kumho V700 VictoRacer tire in 275-40-17 it is a simalar rubber compound to the V710, just an older design. It does have some tread for a short while, but soon wears off to a slick surface with 2 grooves around it.
(NOT a "street tire")
I just got a set of 4 from TireRack 2 weeks ago, in stock then.
Good autocross tire for NCCC, probably a half second or so off the A6, but lasts a hell of a lot longer
Old 07-14-2010, 10:14 PM
vettehardt
vettehardt's Avatar
I've been running the Kumho Victoracer V700s on my 76. Work pretty good and last quite a while.
Old 07-15-2010, 10:37 AM
Gordy M
Gordy M's Avatar
Goodyear has a new DOT race tire Eagle RS that is said to be equal to the Hoosiers but do not fall off as noticeable. Not sure if they are as good auto-crossing but it might be an alternative.
Old 07-15-2010, 02:38 PM
RX7 KLR
RX7 KLR's Avatar
The current Eagle RS would not be a great autox tire, very much like the R1 it needs some heat. But GY is supposed to release an autox version in the future.
Old 07-19-2010, 07:29 PM
dvandentop
dvandentop's Avatar
how many sessions per day?
a user on here who has gone through 20-25 sets of these has told me he usually quits using is after around 25 heat cycles so that is a good amount of time.
Old 07-19-2010, 07:43 PM
0Finspeed
Former Vendor
Finspeed's Avatar
20-25 heat cycles, and they start to really fall off; you will most likely run out of heat cycles before you run out of rubber. The wear is very comparable to the R6's but once heated up, they are stickier than A6's.
Old 07-19-2010, 08:08 PM
Cloaked323
Support Corvetteforum!
Cloaked323's Avatar
Not to Hijack just one question
running CCW 18x11 18x13 rim sizes shod with 295/30ZR18 & 345/35ZR18 What is the proper slick size, I want to be able to run in comp mode.
To Best competiton tire beside Kumho Ecsta V710 and Hoosier a6
Old 07-19-2010, 08:20 PM
dfinke23
dfinke23's Avatar
I run CCW 18x11/18x13 C14's with 30/65 Michelins on the front and 31/71's on the rear. I run comp mode for the first lap, then shut everything off. I ran comp mode at RA for a session with no issues.
dvandentop runs the same setup.
Old 07-19-2010, 08:29 PM
dvandentop
dvandentop's Avatar
threshold yes it works great on road america and also autobahn, i usually warm them up in comp mode but once you do a lap or 2 i turn all the nannies off and let it rip. hold on as the grip on them is insane. i probably have about 12 heat cycles in mine now and still holding strong. that is after around 6 25 minute sessions at road america and quite a few sessions at autobahn also.
Old 07-19-2010, 08:31 PM
Lan.Jet
Lan.Jet's Avatar
About 180Min on the fronts and 360Min on rears. I love the grip but $$$$
Quick Reply: Best competiton tire beside Kumho Ecsta V710 and Hoosier a6
