Hoosier tire sizes for Stock C5 Z06 Rims
Old 07-15-2010, 09:44 PM
Z06 Bob
Z06 Bob's Avatar
Default Hoosier tire sizes for Stock C5 Z06 Rims
Does anybody run Hoosiers on stock C5 Z06 rims? If so what sizes max?
Old 07-15-2010, 11:10 PM
thehammer69
thehammer69's Avatar
295's for the front 17's and 315 for the rear 18's.
Old 07-16-2010, 08:54 AM
Wild Horzes
Wild Horzes's Avatar
I always used 275's and 305's. I felt a little safer with the wheel width, but that's me. I've had 315's all the way around on 17's and wore some nice edges on the front fender wells.
Gary
Old 07-16-2010, 12:12 PM
Cap'n Pete
Cap'n Pete's Avatar
I would agree with 275's on the front (9.5") wheels, and 295's on the rear (10.5") wheels.
Going any bigger will "fit", but you're going beyond the recommended rim width for the tire sizes (or only running the minimum recommended at best) and it's generally best to run the max rim width per given tire, not the other way around.
Remember, factory only runs 265 & 285. Again, given the sizes available, 275/295 is "optimum".
However, that's just my $.02 ... maybe wider tires on (relatively) narrower rims works for some people .
Old 07-16-2010, 12:22 PM
johninar
johninar's Avatar
This is what I run = no issues
I do run stock brakes though.
Old 07-16-2010, 12:31 PM
Wild Horzes
More of my $.02; I've been told that the T1 guys run 295's and 315's on 17's all the way around. My T1 felt great with the 315's all the way around. It was a big difference from the 275/305's on the stock wheels. To me, and again only my opinion, its best to get a set of wheels for the track for the sizes you want to run. CCW's seem to be the standard and they are not too terribly expensive. Of course, for a track day here or there, it may not make a lot of sense.
Gary
Old 07-16-2010, 02:32 PM
Z06 Bob
Z06 Bob's Avatar
Default Hoosiers on Stock rims.
I have a set of CCW's 18x12 with 315's rear and 18x10 with 295's front. Just wanted a spare set and didn't want to spend 3000.00 for another.
Old 07-16-2010, 02:57 PM
jaa1992
jaa1992's Avatar
Location: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps GA
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
I have 4 18x10.5 c5 rims with 275 hoosier R6's
Works well on my c4
Loose nut behind the wheel is the main issue.
Old 07-16-2010, 03:25 PM
fej
fej's Avatar
Factory Z06 was 265/40/17 and 295/35/18. Uncommon front and rear sizes which is part of the reason we pay so much for tires (well us and the P cars)
I have 295/30/18's A6's square currently on factory 10.5" rims. Car seems to work pretty well that way, but I may go 295/315 as the 30 series does change things just a little in the rear from the 315/35 V710 I was running from a top speed and acceleration stand point, but part of that is probably user error
Fej
Old 07-16-2010, 05:35 PM
Armycop
Armycop's Avatar
Like Fej, I'm running 10.5's on all corners, but with 315's. Love the way the car tracks through corners with this setup. Yeah, she rubs the brake ducts at full lock (think Grattan's 270* turn) but no other issues so far.
Old 07-17-2010, 12:36 AM
waktasz
waktasz's Avatar
No issues. Tires fit square on wheels.
Don't know if your questions is autocross or track oriented but all the c5z autocrossers run this size.
Old 07-17-2010, 02:13 AM
longdaddy
longdaddy's Avatar
295f/315r will get you closest to the stock C5Z tire diameter and front/rear height ratio which is the reason I run it. this is with stock 17/18 combo
Old 07-20-2010, 12:41 AM
986_C6
986_C6's Avatar
I ran 305's in the rear, on my C6 though.
Old 07-20-2010, 01:15 AM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
I agree, I think wheel width trumps tire width, and a whatever your wheel width is, the best bet is a properly sized tire on that given wheel.
A Hoosier 295 fits about as perfect as you can get on a 10.5" rim. The Hoosier 275 is a pretty wide sucker (10.3" tread), and it will fit on a 9.5" rim, but a 10" rim is probably about perfect for it. We run them (275's) on the 10.5's and they work well.
Old 07-20-2010, 07:56 AM
TedDBere
TedDBere's Avatar
What are you using the car for? Autox or track?
Old 07-20-2010, 11:42 AM
AverageVetteNut
AverageVetteNut's Avatar
Cruise-In 9-10 Veteran
CI-X Auto-X Champ (race tires)
St. Jude Donor '07-'09
Thanks,Scott... I was just about to ask the same question.
The answer will greatly change the suggestions.
to the OP:
RR guys and some Time trial guys might do a setup way different than us conechasers.
Also, if you're autcrossing, the class you choose will dictate the wheel.
I run 295/17 F and 315/18 in the rear with no rubbing issues as well..
There are a few people i've met that try the 315/17s up front, but there are fender rubbing issues there, and you need to use a spacer to correct that.
Old 07-20-2010, 12:15 PM
sothpaw2
sothpaw2's Avatar
So it's folks have safely run 295-30-17 on the front 17x9.5 width rim? I've been skitish to run more than 275-40-17 on the 9.5" width but my NCM instructor said the car definitely needs more tire in front and I agree--it really pushes at times.
Old 07-20-2010, 01:08 PM
drivinhard
drivinhard's Avatar
It'll fit, the problem is the wheel width is limiting how much of that 295 section width you're actually going to take advantage of.
Running square wheels/tires takes a lot of the factory understeer out. (ie, run wider wheels up front)
To Hoosier tire sizes for Stock C5 Z06 Rims
Quick Reply: Hoosier tire sizes for Stock C5 Z06 Rims
