Z06 315/30 on CCW rubbing on duct? [pics]
Old 07-18-2010, 09:52 PM
andy82
andy82's Avatar
2017 C7 of Year Finalist
Default Z06 315/30 on CCW rubbing on duct? [pics]
Today I was in the process of swapping my auto-x tires on CCW's back to street tires when I noticed that they seem to hace rubbed on the brake cooling ducts.
I noticed this the first time today and assum it is happening now because I installed a PFADT camber kit and ran -3 degrees camber in the front. Before and without the kit (same wheels) I never noticed....
Has anyone seen this on his/her C6-Z?
Old 07-18-2010, 10:05 PM
JDIllon
JDIllon's Avatar
I run 315s but am not running the camber kit. And they only touch when at hard lock. That is one of the reasons I have not installed the camber kit yet. Check to see if they are also hitting on the fender. A friend had them rub there also. And because I only run HPDEs I don't lock to lock as much as you would running Autocross's. JD
Old 07-19-2010, 12:18 AM
dvandentop
dvandentop's Avatar
yep has happened on mine with 305 in the front but not really worried about it much, those tubes are cheap to replace if they would wear through. i only got them from autox i believe and dont do any autox any more really
Old 07-19-2010, 12:22 AM
SIK02SS
SIK02SS's Avatar
Yup, it happens. Don't crank the wheel lock to lock, problem solved
Old 07-19-2010, 12:51 AM
Olitho
Olitho's Avatar
Me too and some heavy duty duct tape over the worn holes from time to time and all is good....
Old 07-19-2010, 01:08 AM
dfinke23
Support Corvetteforum!
dfinke23's Avatar
Happened to me with the Hoosiers, no camber kit and stock bushings. I am now running Michelin slicks, a camber kit and spherical bearings and have no rubbing.
Old 07-19-2010, 07:02 AM
AU N EGL
AU N EGL's Avatar
Yup
Brake ducts need to be replaced every so often too, just normal
To Z06 315/30 on CCW rubbing on duct? [pics]
Quick Reply: Z06 315/30 on CCW rubbing on duct? [pics]
