295/35/17's on a 8 1/2" Rim ?
Old 07-22-2010, 06:14 PM
TEXFRC
TEXFRC's Avatar
Default 295/35/17's on a 8 1/2" Rim ?
I've searched and find only info for Z06's.
I'm currently using 275/40/17 A6 Hoosiers on the front of my non-Z06 '02 Targa for autocross. They working pretty well but I'm thinking about 295/35/17 A6 Hoosiers for the front. I have 315/30/18's on the rear.
Will they fit and work okay on a 8 1/2" rim? Hoosier's recommended rim size is 9.5" to 11"
TEX
Old 07-22-2010, 06:15 PM
froggy47
froggy47's Avatar
For me, I would not.
Old 07-22-2010, 06:19 PM
jaa1992
jaa1992's Avatar
Location: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps GA
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
I'd be a little worried with 275's on that rim.
The 295 I'd want at least a 9.5" wide rim
Old 07-22-2010, 06:37 PM
shakedown067
shakedown067's Avatar
St. Jude Donor '12-'13
A 295 is the max for a 9.5" wheel.
Old 07-22-2010, 07:24 PM
Kubs
Kubs's Avatar
Received 1,753 Likes on 941 Posts
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
It will fit but you wont gain much over the 275 because the tire patch wont be right on the 8.5" wheel.
Either stick with the 275 or get a 9.5" rim.
Old 07-22-2010, 08:45 PM
TEXFRC
TEXFRC's Avatar
I'm in AS can't do that.
Used to stick 285/30/18's on a 8" rim on the RX8 and they worked great.
Guess I'd better stick with the 275's.
Old 07-23-2010, 07:40 PM
corvettenilesg
corvettenilesg's Avatar
so you have 315s on the rear on 9.5s hows that working for you?
Old 07-23-2010, 08:24 PM
RX7 KLR
RX7 KLR's Avatar
Lots of things can be made to fit... But does it work better.
I found 245s to work just fine on my RX-8.
I like the Kumho sizes for the AS C5, 275 front 305 rear.
To 295/35/17's on a 8 1/2" Rim ?
Quick Reply: 295/35/17's on a 8 1/2" Rim ?
