adjusting NPP exhaust
Old 08-10-2010, 04:13 PM
Dirk Miller
Dirk Miller's Avatar
Default adjusting NPP exhaust
How do I adjust my NPP butterfly valves so they do not open all the way?
I will be driving soon @ Laguna Seca where the dB limits are pretty low: 92 dB's. I recently installed different exhaust manifolds and corresponding piping back to my original NPP exhausts.
I am concerned I may be black flagged after going through corner 5 and before I buy $100 worth of turn-downs, I am thinking I could possibly adjust the valves in my exhaust and keep things quieter.??
Old 08-10-2010, 05:40 PM
68sixspeed
68sixspeed's Avatar
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Can you put a lock collar on the actuator rod to limit the amount they open? (not sure which way that is limiting?)
Old 08-11-2010, 01:53 AM
Dirk Miller
________________________________________ ______________
Good idea. Sounds like a simple mechanical solution could be the answer.
Currently, I am out of the country, but will look into this option when I return.
To adjusting NPP exhaust
Quick Reply: adjusting NPP exhaust
