Windows in trailers??
Old 08-11-2010, 09:55 AM
johninar
johninar's Avatar
Default Windows in trailers??
I've been thinking of putting a window in my trailer (24' Pace). I sleep in it at the track. The shop (it's in for some minor fixes) has a 24x36 tinted sliding window in stock. Anyone else done this? I like the idea of getting more light when I'm running the AC it's a bit claustrophobic.
TIA,
John
Old 08-11-2010, 10:25 AM
69427's Avatar
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
I'm in the process of trying to find a window for my trailer. So far I've had very little luck finding something acceptable that will fit between the side structure "studs". I have about 11" of clearance, and most RV windows are too wide.
That's a large window you're describing. How does it fit within all the basic skeletal structure?
Old 08-11-2010, 10:31 AM
johninar
johninar's Avatar
They will weld a reinforcement frame around the window to reinforce the cut. Jim's Motors (Flying A Motorsports) in Missouri is doing the work.
I was quoted 5 hours labor to do the window.
Old 08-11-2010, 10:32 AM
Painrace
Support Corvetteforum!
Painrace's Avatar
If you add them have a way to cover them from the inside so if they are broken there is still no easy entry into the trailer.
Jim
Old 08-11-2010, 10:39 AM
johninar
johninar's Avatar
Jim
To be honest the easiest way to get into a Pace trailer is the side door. A big screwdriver right at the deadbolt and you're in. The deadbolt only travels about 3/8". No big deal for a crow bar.
Old 08-11-2010, 10:55 AM
Z11409
Z11409's Avatar
http://www.lockitt.com/TrailerDoorLocks.htm
Old 08-11-2010, 05:32 PM
varkwso
varkwso's Avatar
I sleep in mine often and the lack of a window reminds me of being in a sub. I would add a window in a heartbeat. You will want a way to hang something on it though to block sun and when the lights are on at night.
You can cut into the side of almost any trailer so I worry less about security.
Old 08-11-2010, 06:56 PM
jawfixer
jawfixer's Avatar
U r right but I have a round master lock on my door too, along with 2 other locks and an alarm system--they would have to cut a big hole in the door to get in--I have over the bar locks on rear--can get them at trailer stores. Can send u pics if you send email i havre the guarded hasp system seen in the previous entry by z11409
Old 08-11-2010, 07:37 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
I, theoretically, stuck a screw in the wall and hang a shirt over the window when there is "No Camping" at events.
Old 08-13-2010, 09:57 AM
Zenak
Terminal Vette Addict
Zenak's Avatar
Im always worried about adding another unsecured point of entry.
Old 08-13-2010, 10:02 AM
johninar
johninar's Avatar
I had them put the window in yesterday. I'm looking for accordion/pleated solar shade for the inside. I have trailer and contents insured, so I'm just not going to worry too much.
I'll let you guys know if it was a bad idea...
To Windows in trailers??
Quick Reply: Windows in trailers??
