camber settings for c6 autox
wanted to ask
what camber setting for c6 on street tires for autox?
also i have the pfadt adj shock and not sure what is the best set for autocross
1 Post
[quote=tailshe;1575054161]wanted to ask
Thanks[/quot
Thanks[/quot
2 degrees neg. front and 1 degree neg. rear work with street tires, with 0 toe up front and 1/4" total toe in rear, as much front caster as you can set with these settings. Been running similar #s for awhile with decent steering response, controllable rear end, and good tire wear on the street. Can't advise you on shocks.
