Anyone using Mocal AOTGM oil thermostat?
This PN is an oil line block adapter and 200F thermostat all-in-one. Specifically, I would like to know by how much, if any, this reduces the efficiency of the oil cooling system compared to one with no thermostat. I would expect something like oil temp in the 240s on the track with a big cooler and no thermostat. If you have this, what is your application, and what temps do you get.
Thanks!
Thanks!
There is a post from a few years ago documenting oil temp that went up from 240 to 265 when a thermostat was installed in the line to the external oil cooler. Also, some say the thermostat imparts a large pressure drop (e.g. a restriction) to the system. However, both of these data points are likely from the older style "H type" thermostat. This integral thermostat and adaptor block is relatively new. I am hopeful somebody has used it and has data.
Any update on this AOTGM device. When i upgrade my cooling system, my car is a daily driver and HPDE as well and I don't want it running too cool. just want to make sure it will keep proper oil pressure with this device in place.
I use and am pleased with MOCAL's 200 degree F oil thermostat.
I come out of my engine with a Canton Racing oil filter adapter using #12 AN fittings and lines:
From there the oil goes into a FRAM dual oil filter housing that is mounted in the left-front wheel well:
Out of the filters I go directly to the MOCAL thermostat:
From the MOCAL thermostat I go into a SETRAB #172 oil cool, and from the SETRAB cooler back to the oil filter adapter:
The SETRAB cooler and MOCAL thermostat keep my oil at 195 degrees + for street driving and at 220 degrees F on the track.
Without the thermostat, my oil would only get to 163 degrees F, which is too cool.
Pumba are you using the oil-take off AOTGM part or the H-style MOcal thermostat? THe inline one would be really nice since it is supposed to fit right in the stock spot.
I am using the MOCAL OT2 type thermostat. Mine is part number AOT2-4HT.
See the following URL - http://208.109.215.220/files/thermos...on+and+Pricing
The following picture shows my MOCAL thermostat in car position:
The view you are seeing is from the left side of a C5 with the front fascia removed. The black tubular piece is the lower radiator support.
