Tranny cooler for an M6 weekend warrior?
Old 08-28-2010, 06:27 PM
vertC6
Support Corvetteforum!
vertC6's Avatar
Default Tranny cooler for an M6 weekend warrior?
Hello all,
I am planning to take my car to the track this year and I wanted to find out what I need for cooling for my C6. I am adding a Z06 oil cooler and I have a M6.
1st. Does the tranny fluid run through the radiator.
2nd Do I need to add an external tranny cooler for a weekend warrior (no serious racing).
3rd If so do I just run and Earl's curved cooler behind the fog light inlet, or a B&M w/ electric fan with thermostat?
Thanks for your help!
Old 08-28-2010, 06:50 PM
rustyguns
rustyguns's Avatar
Originally Posted by vertC6
Hello all,
run 2 full days on the track, log your temps and then decide.
these puppies can take a lot of heat
Old 08-28-2010, 07:40 PM
vertC6
vertC6's Avatar
How do you do it, tap in to the factory wiring?
Old 08-29-2010, 01:28 PM
vertC6
vertC6's Avatar
Anyone else?
Old 08-29-2010, 02:36 PM
longdaddy
longdaddy's Avatar
i believe that yes, c6 z51/GS has trans fluid cooler as a part of the radiator. i have never seen c6 z51 radiator up close so I suppose I could be wrong.
go ahead and do a few days to see if you get the dreaded trans overtemp warning on the track (comes up at about 275 degrees) before you decide if you need bigger coolers.
most likely the stock cooler will work fine, especially if you don't use 2nd gear too much.
Old 08-29-2010, 03:22 PM
gkmccready
gkmccready's Avatar
C6 Z51 also has an EOC in the radiator, so the C6Z EOC makes me wonder if the OP has a base model?
With my C6 Z51 stock radiator I never got a tranny temp warning, but I was hitting 300+F on oil at Thunderhill in 100+F heat.
BTW, if you have a 'vert like your name implies, I'd look closely at the HPDE rules as you probably won't be running without at least a roll bar...
Old 08-29-2010, 03:51 PM
AU N EGL
AU N EGL's Avatar
Anyone else?
trans cooler and oil cooler accusump combo two best mods anyone can make
Old 08-29-2010, 07:39 PM
Fastguy
Fastguy's Avatar
St. Jude Donor '03-'05
The C6 has a trans cooler with the 6spd?
Old 08-29-2010, 08:15 PM
longdaddy
longdaddy's Avatar
Z51, Z06, GS, ZR1 or european base model.
Basically all except base models sold in US.
Old 08-29-2010, 09:46 PM
vertC6
vertC6's Avatar
In the radiator correct?
Old 08-30-2010, 01:27 AM
yakisoba
yakisoba's Avatar
The two biggest benefits of adding coolers are parts longevity and peace of mind. If you are not looking at the gauges every straight, you can concentrate on driving. If you keep the temps cool, your motor will last longer and you can do more track days. What's not to like?
Old 08-30-2010, 10:13 AM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
We sell a kit for the c6 also. It's pretty similar to our c5 kits. They run off electric pumps and you will never know it's there until you throw the switch. The install is a bit of a pain, just being honest. But the results are good when you are done. Send me your email address and I can get you some more info!
Randy
Old 08-30-2010, 11:45 AM
Spectrel
Spectrel's Avatar
I'll be sending you a PM Randy, interested in this as well.
To Tranny cooler for an M6 weekend warrior?
Quick Reply: Tranny cooler for an M6 weekend warrior?
