How to remove shoe polish from a corvette
Old 09-14-2010, 05:03 PM
Red5
Red5's Avatar
Default How to remove shoe polish from a corvette
Usually I clean it off the same day I race. But this last race ran longer than expected and I ended up putting the car in the garage with shoe polish on teh paint. That was two weeks ago.
I don't want to mess up my paint any more than what has happened.
What do you guys use to get shoe polish off of your vette?
Old 09-14-2010, 08:17 PM
vettehardt
vettehardt's Avatar
I usually just use windex and a paper towel. You might have to let the windex soak a little to get it off if it is dried too much. If it's been on there a really long time, I use a razor blade and carefully scrape it off.
Old 09-14-2010, 10:09 PM
flink
flink's Avatar
OK, I give up. Pray do tell, what are you guys doing with shoe polish on a race track?
Old 09-14-2010, 10:27 PM
doje
Support Corvetteforum!
doje's Avatar
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
I've seen a lot of drag strips use it to put car numbers and dial-in times on cars that just show up and run. However, it is usually on the glass, not the paint .
Old 09-14-2010, 11:06 PM
kmagvette
kmagvette's Avatar
Castrol Super Clean or Purple Power. Been using it for a few years and no damage to the paint yet. Wet down the area first, spray on choice of purple stuff and wipe lightly with a terry pad, sponge, etc. Do not let it dry on the paint and use a lot of water to rinse it off. It works very well on the insect parts embedded into your front end as well.
You need to wash the finish with a good soap, like ZipWax, after. Then, hit it with a quick coat of wax and you are ready to get it dirty again.
Old 09-15-2010, 01:54 AM
flink
flink's Avatar
Originally Posted by kmagvette
Castrol Super Purple or Purple Power.
That purple Power is awesome at getting those black tire-booger marks off.
From this:
to this:
in 30 seconds, tops.
Old 09-15-2010, 08:05 AM
kmagvette
kmagvette's Avatar
Purple Power...also available in the 2 Gallon jug
To How to remove shoe polish from a corvette
Quick Reply: How to remove shoe polish from a corvette
