C4 to C5 calipers/rotors
Old 09-19-2010, 05:22 AM
The Bus
The Bus's Avatar
Default C4 to C5 calipers/rotors
I've switched my C4 to C5 calipers/rotors. Front only. It takes almost the entire stroke of the pedal to have a hard pedal/brakes. If I pump them once it is a full pedal like the C4 calipers are with just one push of the brake. The first thing that I suspected was air in the system. Bleed it at least 5 times. Switched back to C4 caliper/rotors and everything is back to normal. Put C5 parts back on [ bleed 3 times ] and same problem. I assume the additional pedal movenment is due to the additional C5 caliper volume?? Problem is ?????? Due all brake boosters have adjustable push rods?? If I extended the push rod an additional amount [ length not yet determined ] will that do the trick??? Or am I missing something?? If so what do I need to do to correct this problem since I know that others have done this???
THANKS FOR ALL SUGGESTIONS/HELP and I do mean HELP.
Old 09-19-2010, 08:49 AM
jaa1992
jaa1992's Avatar
Location: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps GA
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
do a search in the c4 tech section.
I'm sorta remembering some folks had to go to a bigger master.
Old 09-19-2010, 10:54 AM
Aardwolf
Aardwolf's Avatar
I adjusted the push rod on mine and the system is working well. IIRC I left 1/16" gap between the rod and M/C cup. I used a bent piece of metal to measure. Hold the nut and turn the push rod from what I remember.
On long straights I still have to double pump, due to pad knock back.
Old 09-25-2010, 04:19 AM
jwt1603
Support Corvetteforum!
jwt1603's Avatar
I didn't have to change / adjust anything when I converted to C5 fronts. I know several people that switched with no issues. Are all the parts new?
Old 09-25-2010, 08:34 AM
mikemiller68gs
mikemiller68gs's Avatar
I also made this change on my C4 and had no issues. i wonder if the issue is with your calipers. Did you use new brake hoses?
Old 09-25-2010, 10:12 AM
c4cruiser
c4cruiser's Avatar
What year is your car?? Were the OEM front calipers single or dual piston?
When I installed C5 front brakes on my 87, I noticed a very slight difference in pedal travel but the upgrade worked fine. I also installed the Doug Rippie brake bias spring and that didn't change pedal feel at all.
Old 09-25-2010, 05:15 PM
The Bus
The Bus's Avatar
If the calipers aren't leaking what could be wrong with them??? Not saying your wrong just asking???
Old 09-25-2010, 07:05 PM
Sidney004
Sidney004's Avatar
If the calipers were raced( and cooked) or the calipers you bought were used and had been raced, they could of spread; which would give you a long pedal.
Old 09-25-2010, 07:28 PM
The Bus
The Bus's Avatar
Never thought of that. I have a new set of calipers I'll try.
THANKS
To C4 to C5 calipers/rotors
Quick Reply: C4 to C5 calipers/rotors
