Stoptech st40 fitment
I had to use a 1/8" spacer to clear with aftermarket C5 Z06 wheels.
It just clears the caliper. Would feel better with 1/4".
I got Pfadt spacers instead of generic because they fit on the studs and don't move around like generic ones.
good to know.
anyone else have experience with this. Maybe the 1/8 is tight but if it works, why go with 1/4
just want to make sure I get the correct parts to begin with.
they will clear the rear 18x10.5 in OEM rims....most aftermarket rims have thicker spokes, and may not clear. The Stock rears will fit over most brake kits, but not all. I have to run 3mm spacers to clear the PFC kit.
Doubt it, it ships with a 355mm rotor, which is basically 14".
Hmm... There is an option for a 328mm rotor, which would fit, but has this note: RACE ONLY Deletes PB; Pistons Sized for Dual Master & Deleted Booster; Billet Steel Brackets; Pads Not Incl
Former Vendor
If you decide to swap out some wheels to fit some BBK's, check these out from XYZ! Many sizes and options to choose from and the price is simply unbeatable!
http://forums.corvetteforum.com/c5-p...d-at-cost.html
