17" vs. 18" wheels for C5 track car....
I just bought a 2003 Z06 T-1 car. The car came with CCW classic 17" wheels. Besides the difference in turn-in, sidewall height and stiffness between the two, is there any benefit in going to an 18" wheel?
The 18" slicks and dot-r tires are a lot easier to find used if you go that route with tires. . U can also run bigger brakes with the 18" setup. And 18's look better! lol
congrats on the new car..post up some details when you get the chance.
The car was built by Mike Tracy Sr. and Jr. out of Chicago. 2003 Z06. It has a full cage, driver side net, G2X data and AMB transponder, new Saferacer fire system, Accusump, Recaro XL Profi seat with Willans harnesses,removable Sparco wheel, Motorola comm system, Chasecam camera and mount, T-1 springs, T-1 sways, Moton double adjustable shocks, DRM brake cooling ducts, new crate motor and wiring harness, Ron Davis radiator, new Rockland short shift tranny and cooler, ARP long wheel studs, new windshield, front and rear tow hooks, 17" CCW's with A6 rubber, 2 extra sets of wheels and tires and a bunch of other extra stuff.
Car dynoed at 374.9 rwhp and 360.1 torque.
What size tires are you running?
If are entertaining used Rs (like from John Berget tire), that may dictate your choice. I think Phoenix has the larger widths in either size. 17s are obviously cheaper new.
The extra sets of wheels and tires may help with choice as well.
excuse my ignorance but..do the T1s use the stock intake and exhaust manifolds ?
Stano
Hey Stan, if you ordered the AP kit from Gary already you're stuck with either 18's or wait until 949 releases their 17s next year..and those brakes would be an expensive paper weight at home
Check out the Forgestar wheels (Ryne is a vendor for them and gets great prices): http://www.forgestar.com/v1/f14.php
Also for tires, the Nitto NT-01's are great, and cash prices with these guys are nearly unbeatable: http://www.citytireonline.com/NittoNTO1.htm
wouldn't hurt while you're testing to try both the 295's up front and 315's to see which you like better.
Using 3/8" worth of spacers you can get the stock 17" thin spokes to fit over Gary's kit. I haven't tried the C5 Z06 fronts yet. The C5 Z06 rears fit without any spacer (in case anyone was interested).
I thought about the big brakes and 18's for my car, but it's not worth it to me at this point.
$2000 x 2 sets of new wheels -$4k
$4000 for brakes? total -$8k and not that much benefit.
Tim
Tim
Bringing this back up to the top.
I am considering a set of "T1" fitment 17" CCW's for my HDPE car.
Should I hold out for a set of 18's?
This is a fun car that will see the track maybe once per month, and obviously used tires when I can find them are always a bonus. Not trying to set any track records, just have fun and out-run a buddy's stock 2013 GT500.
What what a coincidence, my non-CCW budget setup is for sale here : http://forums.corvetteforum.com/auto...osier-a6s.html
