**Max attainable lateral G**
Guys
Thinking only of DOT compounds and R6, A6 and MPSCs in particular, what is the maxium sustainable lateral G you can regularly achieve.
You would have to set your data logger output to a smoothing of say 5 in order to discount some instantaneous "g's" due to wheel whip and the like.
Quite frankly I have installed the full pfadt coilover and sway bar system on my Z and even with wider (295&345) and better tyres, the lateral Gs I am getting are no better than a stock C5 with 275 & 295 tyres
Thanks.
Thanks.
The Corvette engineers had a pretty good idea about what to do. At least your Corvette didn't get worse. That's what usually happens with aftermarket parts.
Richard Newton
My Speed TV Page
Richard Newton
My Speed TV Page
CI-7-8-9-10 Veteran
Cruise-In IX AutoX Winner
St. Jude Donor '05-'06-'07-'08-'09-'10-'11,'19,'22
St. Jude/CI Name Tag Designer
Most I've seen on the stock run flats at autocross is 1.19 G. With Hoosier A6's, I've seen 1.35.
On my C6 z with new runflats, my g meter was reading a consistent 1.2 around the sweepers at roebling road. Looking at my data from Road Atlanta in my T1 car, I am getting sustained values of up to about 1.5 with hoosier A6's. I would expect similar performance from a stock C6Z with the A6's.
I don't see how coil overs would make a difference for max lateral G in any case (on a smooth track), if the car is weighted properly. You won't get the max until the suspension sets, the springs and shock combo only works in transitions.
St. Jude Donor '05-'08
looking at my traqmate data my g-force at WGI and my max average is just over 1.5 with Hoosiers A6 and hardbar coilovers. I would think there is more room, but that would require me growing some bigger ballz
Location: If you don't weigh in you don't wrestle Road America
Buttermore sees spikes of 2.0 g and sustained in the 1.4-1.5 area, I would think with areo ST2 cars should see a little higher than that.
I've seen numbers similar to Wallys with Geffs ST2/TTS car, depending on track surface.
Forgetting the spikes, max sustainable is around 1.1 and a peak at the apex of say 1.25. That is just the same as it was in the C5 automatic.
I had expected the 1.5 figures you guys talk about and because of that I installed the ARE Stage 3 oil system
This is not about *****, those are the figures where the outer wheel starts to skate and balance is lost.
The coild are set at the pfadt recommended settings and there is no appreciable under or oversteer. Its hard on the road but nice abd really stable on teh track. At 280 (km/hr) the car is rock solid
Alignment is same as teh C5 with -2.5deg front and -1.5 rear. I did try -3 front but noticed no difference. Rear is better at -2 but braking suffers at that
I have a little toe out front and a lot toe in at the rear. Everything is like the recommendstions on this board.
You have to throw away any data that is on anything but a flat surface. Lots of road courses have some subtle banking and that makes the data junk for comparison purposes. I've found that measurd grip gets much larger even with a slight banking effect.
I think you will find real data on a flat surface to be lower than 1.5 most all the time, and more like 1.3-1.4 is pretty much it unless you have aero or some banking.
1 Post
W. Detroit Events Coordinator
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VII Autocross Champ
Is downforce really help at those low speeds? At what speeds does DF help? 80+
I would discount transient G's (instantaneous maximum).
What I find more useful is the 98th percentile of the maximum G cumulative distribution function (ie, this has the effect of maximum sustained G load).
The single biggest factor is tires and tire size. On Hoosier A6, I have seen 1.55g at 98th percentile (this is a car running wide tires on a really wide rim).
the more aggressive springs/bars etc help with transitions more than outright grip....unless you are carrying a tire through the corner, maximum sustainable grip is pretty much determined by tire compound.
You've got a problem somewhere. My C6 Z51 on Toyo R888 275+305 can easily pull 1.2+G with peaks well above that. Mods are DRM coilovers, original Pfadt Pfatty swaybars, Pfadt poly bushings, and Wilwood front brakes. But none of those should really give me better grip on a smooth surface. Alignment is -1.75 front, -1.25 rear. Tick of toe-in front, 1/16" toe-in rear.
that's about all I get "normal" average I guess, running 275 A6s. some spikes to 1.75+ but most of the norm is in the 1.3-1.4 range
From what I have read I think 60 mph but you won't feel it in your body. I mean stick you hand out the window at 60 and angle it and you will feel down-force. Slow track more wing as you are not worried about high speed drag.
Grip levels and track temperature
OK. Thats great feedback - but let me broaden the discussion
For those of you pulling say 1.4 and above, does track temperature influence the results?
Does a hot track grip better than the same track when cold? Say its 18deg C in winter and 36deg C in summer, what (if any) is the difference in grip.
regards and thanks - John
Does a hot track grip better than the sam etrack when cold? Say its 18deg C in winter and 36deg C in summer, what (if any) is the difference in grip.
