Gear Oil recommendations, please
Gentlemen,
From those of you who are running the C4 ZF 6-speed box for ROAD RACING, what are you using for gear oil? We are much more concerned with gear wear protection and cooling than with long-lasting properties.
First-hand experience only, please. Thanks,
Ed
Ed
Amsoil MTF user here:http://www.amsoil.com/storefront/mtf.aspx
100+ track hours(though not all of it on MTF), 77K miles, original clutch, shifts smooth. These are really tough gearboxes, of all the things that can go break racing a C4 Corvette, I think the ZF 6 speed should be the least of your concerns. Also, I have never heard or read about the ZF being prone to overheating. The black tag version is supposed to be beefier than the blue tag.
Thanks!
Sidney,
Thanks again for a very learned opinion, and the web site link! We have heard good things about the Amsoil product, and it would be a big bonus to NOT have to plumb a tranny cooler.
We were devout users of Redline synthetic until we prepped a 911 several years ago, and discovered that gearbox thrived on Swepco, and essentially "rejected" everything else. Since then we realize that different box configurations "prefer" different lubricant formulations.
Are you personally using the base 5w-30 viscosity range for track/racing? That seems extremely light weight to me. We appreciate your advice.
Ed
Ed
Sidney,
Ed
Ed
Hi Ed,
I used the RedLine for many years with no problems. Currently using the Amsoil-local Dealer close to my house. I am pretty sure that the Amsoil for the ZF has only been available for the past 5 years +/-. If I am wrong I am sure someone will correct me.
I have also been using the RedLine power steering fluid (since 2001) with an underdriven crank pulley-no issues.
Steve
Steve
66IISS and Steve,
I am doing this from memory, but the Redline Shockproof is available in 75w-90 (which we use in Hewlands), and (I believe) 80w-100 that is used by F-Atlantics with Webster gears.
So, 66IISS, when you write "light weight", are you referring to the 75W-90 viscosity, or something even lighter, like one would use in a motorcycle?
My primary reason for asking is that the spec for Sidney's Amsoil MTF appears to be 5w-30, and that is a long way from the 75W-90 we are accustomed to. Indeed, if the ZF box likes a very light oil, we'll be happy to give it exactly what it likes best. Just want to be sure.
Thank you for your continued clarification!
Ed
PS: Steve, thanks for the additional tip about the PS fluid. We know these units to be problematic when placed under high stress.
Ed
http://www.bobistheoilguy.com/cms/in...d=48&Itemid=55
Gentlemen,
Ed
Ed
Sidney,
I appreciate the clarification - you are a fund of information. Thanks for the great chart!
Pumba,
There's our HEAT, isn't it? No, we will not sport 1200 HP, RW or otherwise!
I find it just facinating how so many racing specialties have their own, minutely specific, requirements! Hardware (and lubricants) that are more than sufficient (even over-kill) for one type of event, are found sadly lacking in another, similar form of racing.
Ed
Pumba,
Ed
One last time . . . . .
So, Gentlemen, just to be absolutely certain -
The Amsoil Manual Synchromesh Transmission Fluid, being a lubricant for (primarily) gears, does NOT use the Gear Oil viscosity grading system? Instead, it uses the SAE Engine Oil grading system?
As such, when the Amsoil product is marked "5w-30", its true viscosity is roughly equivalent to a product using the Gear Oil grading system, and marked, say, "70w-85".
Are all these statements correct?
Thanks for a final double-check. It's giving me a headache!
Ed
Ed
Bill at this website is helpfull if you have more questions. http://www.zfdoc.com/techinfo.htm I've been using BMW 10w60 with no troubles, but it's only seen about 15 track days.
