2 piece rotor question
I have a set of 2 piece rotors coming. They will last much longer than than NAPA's. What other benefits have you racers found from these. Does it affect fade?, pad wear?, will they dissipate heat better?
thanks
thanks
Unsprung weight at the wheels and sprung weight at the wallet.
The quality of the materials of the ring and how many vanes are in the ring will have the the most to do with how long they last and what their thermal capacity is.
Fade and pad wear are all up to the pads you use.
They reduce the weight of the car.
