First track tires - which ones and from who?
Tired of cleaning up street wheels after track days so I got stock Z06 wheels for track days. I have 4 17s and 4 18s so I can go either way. Realistically only have 3 track days left this year so that is all I need for now. Which ones are a good start and from where? Also, do you balance them or just mount them? Anything else I need to know?
Get scrubs from GT Race Tires (414) 350-6303 (Todd) or (414) 640-7218 (Greg). They have R888's and Hooier race scrubs for I think $100 per tire. They have lot's of 18 inch options to choose from. Do a search and you will find their post.
305/35 fit fine on 10.5" stock rear wheels. I believe 315/30 would as well I just haven't tried it. Check the specs for the particular tire you are going to use.
I run the 18x10.5" Z06 rims on all 4 corners. On my car (99) the biggest rubber I can get on the front is in the 275 area or I will start to rub the DRM brake ducts when turning (like in the paddock). So...I usually run 275 all around just to allow for rotation.
If cost is a concern, keep an eye out for scrubs. Frequently on this forum, or on Ebay, or there are several dealers who sell scrubs (as mentioned above).
In spite of trying to get 4 tires all the same, the reality is, I get whats available and often times this leads to different tires or sizes front and rear. But I wouldn't say that has caused me issues, it just takes a little adaptation in my driving from time to time.
Regarding balancing: there are those who do and those who don't and both seem to make out ok. Interesting tidbit: I just put 4 new tires on last week, including balancing and then did a track day on Saturday. Before going out I marked all 4 rims/tires with a paint pen to show where the tire matched the rim. Then I did the first session. When I looked at the marks....the front tires had rotated on the rims. One of them about 10 inches and the other about 3. The rears did not rotate. I did three more sessions and they didn't rotate anymore, which was kind of interesting. Based on this I say why bother balancing them. Maybe balance the rims only next time.
Johnny,
My recommendation is a set of Nitto NT01s. 275 fronts and 315 rears. That is what I run as my practice/lapping set. It is a pretty good sticky tire with a good life.
-Kevin
-Kevin
Actually not wanting to buy a new set until the spring. Would like to get some cheap scrubs. I just put $1200 BFG KDs so I have back up. I don't have front brake ducts so it seems like the squared 315/305/295s. Calling GT tires today to see what they got. Thanks.
Will be getting new tires for next season and was thinking of running 275's square. I run hard and wear them down fast so this size seems to be more economical. Think there will be much difference from my 295's as far as grip?
St. Jude Donor '11-'12-'13-'14-'15
So then a square 275/18 would be just fine huh? I have the DRM/Quantum ducts to worry about up front...
Do any of you run a higher sidewall in the rear?
Tim
Tim
