NASA ST-1 Project Build - Lots of Pics
Old 10-11-2010, 06:22 PM
jkittleson
jkittleson's Avatar
Default NASA ST-1 Project Build - Lots of Pics
I have finally decided to make my C6 a dedicated track car to race NASA ST1 next year. This thread will be to document the process over the next few months...
And it begins...
Waiting on front fascia, Lemans tunneled undertray, hood and fenders from Kerry at ACP.
Hardbar AP Brakes
How do you like this brake ducting?
Old 10-11-2010, 06:41 PM
SIK02SS
SIK02SS's Avatar
UH OH, a new race car in the works!! LOVE IT!! Keep us updated on the build!
What are the engine plans?
Old 10-11-2010, 08:07 PM
CHJ In Virginia
CHJ In Virginia's Avatar
This build is going to be fun to watch. Please keep us in the loop as you progress -----
Old 10-11-2010, 08:11 PM
jkittleson
jkittleson's Avatar
Built the motor last year. Forged 427, LS7 block, katech pistons... Made 567 rwhp
Here is the engine build thread - http://forums.corvetteforum.com/c6-z...age-3-a-2.html
I ordered a ARE Stage 3 dry sump system for it today. I figured since I'm am going with a wing, it was time to pay for some insurance.
I need to figure out how to bring it back to around 520 to run with the weight/hp ratio in ST1.
Old 10-11-2010, 11:27 PM
SIK02SS
SIK02SS's Avatar
Niiice. Which wing you going with? A good tuner can get the power down easily
Old 10-11-2010, 11:39 PM
dvandentop
dvandentop's Avatar
damn this thread will make me jealous I am sure.
congrats on going full out race car!
Old 10-12-2010, 09:44 AM
jkittleson
jkittleson's Avatar
I really want to run the Griggs "Hardbar" or ACP wing, but they are both 3000 without mounts, I may end up using an APR GTC-500 wing.
Old 10-12-2010, 10:50 AM
Bink
Bink's Avatar
Cruise-In V Veteran
St. Jude Donor '09
Look for a used APC wing. Thay are out there. I bought one about 6 months ago, here on the forum.
Old 10-12-2010, 11:52 AM
clubracer6
Support Corvetteforum!
clubracer6's Avatar
Can you tune that motor down 200hp??
ST2 is where the big fields are going to be!
Old 10-16-2010, 02:27 AM
jkittleson
jkittleson's Avatar
Default Pulling the motor
Before...
Ready for the drysump. Now wondering if I should go ahead and machine the block for piston squirters...
After...
Who needs AC?
Old 10-16-2010, 07:26 AM
BuckeyeZ06
BuckeyeZ06's Avatar
A suggestion for your build: keep an eye on the SCCA STO rules and see if you can make your car legal for both series. This doubles your opportunities to race.
My car can run both, and I plan on doing so in 2011, especially with NASA's championship at Mid Ohio this year (and next).
Old 10-16-2010, 12:03 PM
dvandentop
dvandentop's Avatar
how hard was it to disconnect all the bolts for the torque tube to pull motor out the front??
Old 10-16-2010, 12:27 PM
C6RAPTOR
C6RAPTOR's Avatar
I also just ordered a ARE dry sump system for my 05 LS2. This is going to be a winter project. The car is up on my lift at this time draining the oil and water.
Does your existing oil pan have a oil temp./level sensor in the right side like my LS2 engine has (see attached)? If it does where are you going to install it in your new dry sump system. The ARE oil tank does not have a port to use. We need to stay in touch for this project.
gary@grbowler.com
Old 10-16-2010, 05:17 PM
jkittleson
jkittleson's Avatar
It's really pretty easy. I suspend the motor with a hoist, pull the cradle and remove the bellhousing bolts. I've done it this way about a half a dozen times. =)
Old 10-16-2010, 05:20 PM
jkittleson
jkittleson's Avatar
gary@grbowler.com
I'm still waiting for all the dry sump parts to arrive. Not sure what to do with the sensor yet. My email is john.kittleson@hotmail.com
Old 10-16-2010, 06:03 PM
C6RAPTOR
C6RAPTOR's Avatar
I just sent email with photos
Old 10-16-2010, 09:36 PM
dfinke23
dfinke23's Avatar
...easiest way.
My ARE tank has the sensor port.
To NASA ST-1 Project Build - Lots of Pics
Old 10-16-2010, 10:04 PM
C6RAPTOR
C6RAPTOR's Avatar
Originally Posted by dfinke23
...easiest way.
Do you have the 7030 tank? Did you screw in the oil temp/level sensor into that port?
Can you send me a photo?
gary@grbowler.com
Old 10-17-2010, 03:35 PM
dfinke23
dfinke23's Avatar
gary@grbowler.com
I'm not sure what model # the tank is, whatever comes with the 2 stage system; and I did screw the sensor into that port.
Next time I have the fender liner off, I'll take a pic.
Old 11-08-2010, 05:39 PM
jkittleson
jkittleson's Avatar
It's been a busy month. Parts are finally starting to trickle in. My ACP WC bodywork came in today
ACP Hood
Tunneled Undertray
Mockup of ACP Bodywork
Cage Pics
These bars were a pain to get bent
I still have quite a bit of cage work to get done, then start prepping the body parts for paint.
Quick Reply: NASA ST-1 Project Build - Lots of Pics
