LS3 catch can mounting location???
Where are you guys mounting oil catch cans on LS3 cars? The stock air filter has a box right where most people mount the catch cans. I am thinking that the back of the front bumper is going to be the best location. I would like to see some pictures of where you guys are mounting them.
Thanks,
Charley
Thanks,
Charley
Thanks,
Charley
Thanks,
Charley
Ed
Charlie, be careful here, DH may be fishing for secrets to use against us in the CC
Ed
Charley
I am still trying to figure out how to catch him....I have to find a way to overcome that extra 70 HP that he has.
Howie, There are two differences here: First, On the LS3 cars there is an intake resonator located where you have your can located, so we need to find another mounting location (and there are not many options. Second, your can looked like it was designed to have the bottom unscrewed to empty the contents, while the top remained in place on the mounting bracket...The can Ed and I got doesn't operate that way. Ours is designed to stay mounted in place and there is a valve located on the bottom that gets loosened to drain the oil. So this means that it needs to be located in an area that allows access to the bottom.
Charley
Charley
Just because the can has a petcock, doesn't mean you have to use it. You will not be emptying it very often. Except for ACS I can run all day with the small one I have. Even when I had the AMW can with the bottom valve, I still unscrewed it. Just seemed faster and easier than climbing under the car with a hose and a bottle. You will eventually see it my way .............
And as far as you and Ed catching me ......... Hahahahahahahahahaah !!!
DH
Charley
DH
DH
- Remove FRC's - 20HP
- Install Catch Can - 10HP
- Paint Brake Calipers - 10HP
- Polish Exhaust Tips - 10HP
- Play music louder - 10HP
- Wear Light Weight Clothing - 5HP
- 2 Coats of Rejex - 5HP
That should do it .....
Ed
Here is my plan to even the playing field with DH:
Ed
Ed
DH
Charly remove the petcock that comes with the can and go to the hardware store . Get a petcock that allows you to hook a hose to it. Cost $6.00. Don't for get to get a hose to atach to the petcock.
Tris
Tris
Charley,
I may just mount in the standard position and then remove by disconnecting lines when I have a need to empty from the bottom.
I have a killer bee CAI so the noise unit does not apply to me
Ed
Ed
Here are some pictures of my Catch can installation.
I put a quarter turn ball valve on the bottom of the can with a short hose to drain the oil. I also reversed the hose fittings so that they face up.
I located the catch can nest to the radiator (against the frame). To empty the catch I put the drain hose into an empty oil container (under the car near the radiator shroud), and then reach down and open the ball valve.
I am still making the final adjustments... but, I like how it it is working out so far...
Good installation job. Now please make sure you don't spill oil all over the AS garages and pit areas of other tracks.
Also I suggest you measure how much oil your can holds when full so when you do empty it at the track you can determine if your exceeding your capacity.
DH
DH
DH
DH
Measuring the amount that comes out is a good idea.
when I took my airbridge and filter out to give me more room to do the installation there was oil everywhere. I think this should really help. Thanks for providing such a graphic demonstration at the track....That is what made me realize how big an issue this is.
DH
