ZO6 rims and a Wilwood BBK
Received 8,928 Likes
Are you talking about C5Z rims? The LG G Stop kit uses the SL6 wide body caliper and it will fit under the C5Z front rim but that setup only works with stock size rotors. The Z wheels have a pocket that is pushed outward just off center of the wheel and the caliper fits in that pocket. Going out another half inch in radius might make them hit the backsides of the spokes.
Bill
Bill
Bill
Bill
Here it is.
I haven't been to their site in awhile, but I'm noticing that they have added a note saying that a 1/8th spacer is required to run factory rims.....however it doesn't specify between the base coupe and the ZO6.
I don't mind running a small spacer if that's required.
Superlite 4R Big Brake Rear Brake Kit For OE Parking Brake
Click To Enlarge
Click To Enlarge DESCRIPTION
Billet Superlite 4R four piston calipers are combined with BP-10 compound pads and 13”-14” rotors in this group of big brake kits for custom high performance street and show machines. This group of specialized kits for cars, trucks, and SUV’s retain full use of the OE parking brake, master cylinder output, and ABS where used. SL4R rear kits provide complimentary style and performance with 13” and larger front brake upgrades in conjunction with wheel, tire, and suspension upgrades. Optional caliper finishes and rotor designs enable the builder to match style and performance on all applications.
Note 1. 14" Rotor
Note 2. Kit will require aftermarket wheel spacers of 1/8th" (not included in kit) for rear kit installation with OE wheels.
Click To Enlarge
Note 1. 14" Rotor
That's correct, I'm only worried about the clearence on the rear brakes.
I'll level with you guys, I'm actually asking the question because I want to throw a set of rear wheels with drag radials on to do some quick runs down the track. Knowing that this is where people run these type of rims and BBK's I figured I'd have better luck here figuring out if these would fit.
Send a PM to kmagvette. He runs the Wilwoods on the rear of his C5Z. He just posted some Wilwood rotors for sale in this section a few minutes ago.
Bill
Bill
