SS brake lines??
SS brake lines??
I just finished installing new SS brake lines, rotors, and pads getting ready for first event. Went out to bed the pads and the SS lines are rubbing on the wheels. I doulle checked and put the short in front as directed but they are still rubbing. Any ideas of what I might have done wrong???
Former Vendor
The clocking of the line is off. The line needs to be bent inwards. A a couple lose zip ties on the line and upper rear control arm will for sure hold it away from the rear wheel.
Randy
Randy
Did you tighten the non-caliper end of the line first? You might be able to loosen the non-caliper end of the line and rotate it to minimize the interference.
Received 1,754 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I like to install mine with a slight twist in them so when the suspension compresses the hose makes a loop instead of hitting stuff (if that makes any sense).
Once you clear the interference, putting some Teflon spiral wrap over the line will help distribute the flex and give it some additional abrasion protection...
