Have a cage in a C5? Can I see pics of your gutted door shell?
Starting the prep for my cage install. Due to my height I will be getting a bit more invovled than most in that I will be removing the roof and cutting out the factory main hoop. I'm also gutting the doors and losing the windows and everything associated with them.
I'd appreciate pics of your gutted door shell so I can see where you cut and what items you retained if any.
Any tips/tricks would be much appreciated.
Thanks Aaron... it looks like you kept a good bit of material around the door handles. Was that done for any particular reason i.e. to maintain structural support?
Did you remove the factory door beam, can't tell from the pics?
Thanks!
Thanks!
Easiest thing to do is to pull the doors before you take it to the cage builder. Then hang the door and cut it to fit or mark it with a sharpie, pull it back off and then cut it.
My door bars are a lot higher than Aaron's and some others I've seen (like Phoenix cages). I didn't specify to my builder what height to put them at, but I'm glad he did it the way he did. Not that I'm gonna be hit by an F150 in the door while on track, but it's always possible that a car could get slightly airborne right before it t-bones me.
Climbing out isn't an issue since the door would likely be closed anyway.
Mark's seat mounts are too high for me... I have to sit on the floor to have any chance of fitting.
Did you keep your factory inner door handle? I think I need to pre-gut the door because I want the door bars to extend out as far as possible to make getting in/out as easy as can be.
He changed it when the cage went in. There's no way any mount could be any lower. The only thing that's between his **** and the fiberglass floorpan is the 1/8" plastic of the seat bottom.
Travis, Thats just how it was cut around handles. T1 rules at that time we were close on weight and couldn't afford to cut more weight out.
The door beams were not allowed to be removed per T1 rules also. My buddy cut his out and SCCA tech put him on the trailer.
I just need to be about 5' 6"
St. Jude Donor '06
the bottom of my seat is 1/2" off the top of the hardbar mount. to even get it that low, I had to shave the bottom of the seat itself. To go 1/2" lower I'd just have to ditch the hardbar rails and sit it on the floor and weld up a mount to fit the seat mount bolt holes.
johnny
Yeah I'm considering cutting out the OEM floor under the seat so I can get it that extra 1/2" lower.
Anyone cutout the entire inner door shell other than the vertical and lower horizontal part i.e. the part that holds the weatherstrip? Most I see keep some part of the upper part of the inner shell, but messing with my doors tonight I think you could cut that all out and the main door bar.
Sure it'll be flimsy, many race cars have flimsy shells for doors... you just can't use them to get in/out of the car.
Here's mine professionally built Roll Cage by Precision Chassis Works, Gilbert AZ. Great welds, precision cutting, everything got a purpose and light weight. Windshield aluminum frame and Corvette's dash bar incorporated in the cage.
Driver Side
Passenger side
Welded directly to the frame in mulitple places.
Welded directly to underdash factory cross member.
Driver Side
Passenger side
96solo, I really like the CLEAN design of your cage....wish I had the patience and skills to do that.
I agree with many above, the door skins get really flimsy without some of the inner facing left in tact. One bump up with a competitor can leave you without a door at all, as well. You might find yourself replacing them soon than you want to.
96Solo.... your cage work is beautiful, but I'm 6'4" 240 with wide shoulders. I couldn't sit in your car with your main hoop like that.
For my setup I'm removing the roof and cutting out the factory main hoop, then removing the inner roof support rips to free up as much room as possible.
Believe it or not, but your car has been on track with me when Darrell Rayburn owned it.
When the car is finally completed is will run in NASA TTS/ST2 classes. Precision Chassis Works is now one of the NASA-Az inspectors. I love to get the work done right the first time.
D. J. Covert
