Why can't we use the C5's existing structure for a cage?
The C5/C6 isn't built like any other car out there... the windshield frame is designed as the convertible so it can withstand a roll-over, and it already has a main hoop from the factory that's part of the chassis.
Why couldn't a cage builder connect the A-pillar to the main hoop, then use the existing main hoop to build the rest of the rear of the cage and the door bars off of?
Would make for a very roomy cage install....
i absolutely agree !!! this car is like no other and those simple ideas would make such a nice big roomy race car!!!
I have thought the exact same thing but these clubs have built there rules on age old ideas ,,good luck changing anything!
Yes that is what I'm doing.... removing the roof and cutting out the b-pillar. Just annoying to have to do all of this when I've already got a perfectly good main hoop!
Former Vendor
Where is the picture of the Yellow C6 with the b pillar crushed to the door level when you need it??? The factory A pillar is basically junk in my eyes, every car I have seen that was rolled over that has been broken. The B pillar is pretty strong but nothing compared to a 1 3/4 .120 wall tube. If you could attach other bars to it, you would have to put mounting plates on it aka uni body like build.
Smaller cages are stronger.......
Randy
Randy
Randy
Randy
I know the pictures you're talking about... I guess the real thing to do is just cut it all off and make the cage the roof and then use the WC roof skin and lexan front/rear... but that's more than I care to spend. As the goal is to still have funds to actually run the car
D.J. Covert
Yes, it will pass as it is 1 1/4 x 1 1/4 steel rounded square support is much thicker than the required tubing used for the roll bars. Seems like few realize it is there. Did you see the 1/4 steel flange Precision made to connect to the under dash support? This wasn't just an add-on roll cage, but designed to be part of the original car. Did you see the bends and welds? The tubes were sealed and argon was put into the tube before welding to make the inside of the weld as strong as the outside. Then they cut off end plates to attach each piece. Amazing work! Precision's specializes in building SCCA Boxster Spec cars. My Corvette was lonely with all the Porsches down there. They are very good at race prepping cars for those two sanction organizations.
Former Vendor
Randy
if you look at the NASA CCR, the dash bar is considered "optional"
I am running a new dash bar (tossed the OEM one) so I can hang a new column and instrument set up, the OEM cluster sits way too high for me. But you're 6'4" so probably no issues there.
I didn't realize that... I should have looked your setup over more closely. Are you running an entirely new column and cluster, or did yuo just lower the stock column down and set the cluster lower?
