Who makes a 1963-67 C2 autox seat?
I'm looking for an autocross seat for my 1967 roadster that is still basically a street car. With DOT 100 Nitto NT01 tires I slide all over the interior, and soon I'll be upgrading to much stickier Kumho V710s. The car gets a custom harness bar and harness next week as a first step in keeping me planted in the stock seat. However, I anticipate needing a seat with better torso bolstering. I still cruise around town and take trips in the Vette, so I can't use a Kirkey or other dedicated race seat; I need something more comfortable. Has anyone found such a seat that fits in a stock 1963-67 Vette?
When I ran my 64 I used a seat from an 81 and it worked very well...also had a roll bar and 6 pt harness. Also put a steering wheel from a 71 and that made it much more manageable to autocross than the original. For the seat I added a 1/2 inch shim in the rear bolts to adjust seat angle but cannot remember if that was for me or for when my daughter started autocrossing.
I saw an ad somewhere for a set up you can use with your existing seat. Looked like a couple of pillows on each side connected with a non skid fabric that you sit on, effectively pinning you between the door and the center console and keeping you in place for autoxing with no alteration to your car. Looked like kind of a neat setup and a lot cheaper than a new seat.
Sorry I don't have any more info than that; I'm just going to steal the idea for when I get the body back on, and then build my own...
I already have a padded C3 steering wheel and it helped a bunch. I also have the Jeep steering box, which reduced lock-to-lock from 3.5 turns to 2.25.
C-2 Autocross / Street Seat
I would lean toward the Corbeau A4 for a good compromise seat that is a break back to allow access to the rear compartment and adjustment for rake. I know they have seat tracks for the C-3 and suspect they would have for a C-2 also. Check out their website for pricing and to be sure they have a slider to match. The A4 or the TRS look like the best choice for both autocrossing and street driving.
The aluminum seats are great for track and autocross but just are too hard to get into and out of and lack enough padding for any extended street driving. I had one in my last C-3. The series 41 (Pro Street Drag) from Kirkey would come the closest to being useable.
I intend on going with a Corbeau Clubman in my current C-3. It's a convertible so getting to the rear compartment isn't as much a problem as on the coupe. It looks period correct for the older cars too! We ran it as our race seat on the C-3 I crewed in IMSA and SCCA back in the early 70's. It just does not have the rake adjustment so you'd better like the back to seat angle.
Have fun autocrossing that C-2. If I could have afforded one, that's what I would be doing but had to settle for a C-3 once I decided to get out of the newer car ('96 LT-4) for something that was easier to work on and had more personality.
Now tell me about using a Jeep steering box to quicken the steering. I've missed that mod on the forum and with power steering might be able to use it.
(Yes Joe and Capt. Jack, I'll bet it's not legal in Gp. IIB with NCCC. I need to just get over it and run what I want on the car in Group III. I'd get my butt kicked but have the things I want to do on my street car!)
Locke McCormick
North Florida Corvette Assn., NCCC
Buccaneer Region, SCCA
Jacksonville, FL
Locke McCormick
Jacksonville, FL
I used the angel tech wings last weekend on my C6 for a local autocross. It worked great! You are really locked in the seat for autocross and when you are done it just pulls out and you are back to normal. I bought mine in the winter prior to a price increase. But it would take a bunch of time to sew together something that would do the same job. And racing seats are pretty costly.
Locke,
I hadn't paid any attention to the TRS, but now I likely choose between it and the A4; thanks for the suggestion.
Here are a couple of links to the Jeep steering conversion:
http://forums.corvetteforum.com/c1-a...o-my-67-a.html
http://forums.corvetteforum.com/c1-a...ory-style.html
http://www.corvettesteering.com/index.html
As said by several CF folks, including me, if you can only make one mod to your early Vette, this is the one you want. In addition to the way waster ratio, you also eliminate the dead spot in the steering wheel when you're going straight down the highway. No more sawing slowly back and forth on the wheel to keep going straight. Search for "Jeep steering" in the C1/C2 and C3 CF sections and you'll find a ton of happy posters. I don't recall anyone on a forum regretting putting in a Jeep box.
Lou
Locke,
Lou
