Removing OEM belts ?
Old 03-30-2011, 01:32 AM
bsbinict
bsbinict's Avatar
Default Removing OEM belts ?
I am about to put in new seats and 6pt belts in a 98 coupe. Can you remove the OEM belts? And if so can something be done about the belt light (dash)? Thanks
Old 03-30-2011, 01:39 AM
travisnd
travisnd's Avatar
Since it's a C5 once you unplug the stock seat it won't register the MIL for the seat belt not being buckled.
Old 03-30-2011, 07:35 AM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Street car? You're going to wear 6pts all the time?
Old 03-30-2011, 08:43 AM
CHJ In Virginia
CHJ In Virginia's Avatar
If you are going to drive the car on the street with the 6 PT belts, you are not legal. The 6 PT harnesses are not DOT approved and you leave yourself open to a citation if stopped for another infraction. They would be a PITA for everyday usage anyway.
To Removing OEM belts ?
Quick Reply: Removing OEM belts ?
