Anyone cut the stock aluminum/balsa floor pan out?
I've heard you can cut the stock floor pan out and replace with sheet-metal to get even more head-room? Anyone do this? Any pics or tips?
I curently have a custom Ultrashield seat mounted on Hardbar seat rails. The bottom of the seat sits on the floor. If I'm thinking correctly, you could cut out the stock floor, retain the factory metal ribs the seat studs sit in, and then replace with sheet-metal and new seat studs that are threaded properly?
Current setup
Current setup
No... but currently the seat rests on the stock floor... the stock floor is about 1/2" thick.... replacing that section with sheet-metal will allow the seat to sit even lower.
I don't 100% need it, but looking at the pics of my driving and seeing where my head is in relation to the roof another 1/2" would be helpful.... since the car will be torn apart for the cage it'd be the easiest time to do it.
Nothing would hang below the car, from the underside nothing would look any different other than a patch of sheet metal in the seat area.
This guy sure did.
http://forums.corvetteforum.com/c5-f...ld-thread.html
Probably a little over kill for what you're thinking.
Even if you were allowed to do it, sheet metal isn't going to cut it. Those support braces are very flimsy and could never support your weight. You'd have to use a steel plate welded to both frame sections.
Talk about left side weight issues.
If for some reason Greg lets you do it (which he's not ) or if the car was being built for fun, I'd do both sides just to offset the extra weight.
The Panoz is just square tube with sheet metal on top... works fine. I could have sworn I saw a C5 build by Blackdog racing where they cut out the stock floors and replaced with metal for safety.
just cut slits the width of your seat rails, and recess the rails down into the slits. You can still use the OEM reinforcement, 99% of the floor, but get the seat down "into" the floor. If you are careful, you could even cut the upper layer of fiberglass, the balsa, but leave the bottom of the floor (underside) untouched.
In World Challenge, they briefly worded the rules such that you had to replace the OEM brackets with tubing. What actually happened was that some team cut out the entire floor (including the reinforcements) and just bolted the seat to sheet-metal. When they got caught, SCCA thought there were no reinforcements in the OEM floor and added that rule. Once they realized the OEM supports exist, they allowed them to be used.
Mike
I was going to build the roll cage out of 1.5" angle.... I can get it at Lowes and Home Depot pretty easily...
Location: If you don't weigh in you don't wrestle Road America
If you look closely you can see the seat is lowered down the thickness of the balsa wood.
