Tie Rod end options...... bump steer kit??
Old 04-02-2011, 07:42 AM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
Default Tie Rod end options...... bump steer kit??
So a customer's car need outer tie rod ends.... bet you can't guess why!
Anyway, tie rod ends have gotten expensive, so much so that it is just as cheap to buy Zip's bump steer ends instead. No so much as a performance upgrade, just something that won't melt.
Anybody done this, have an opinion one way or another.
btw, can't find VBP's tie rod ends, their site is being very hard to navigate. Mood ends are $64 at Rock Auto.
Old 04-02-2011, 10:07 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
your right that VBP web site sucks! I could not get to any C5 or later tie rod ends.
Old 04-02-2011, 01:25 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Easiest just to call them
Old 04-02-2011, 01:29 PM
John Shiels
yes but why have a web site? Web sites are nice because they are 24 x 7 and during the week it is hard to do stuff like on the weekend. I like VBP but the web site doesn't let you find tie rod ends for a C5 or 6 mean web master needs flogged! I see sometimes companies make a new web site and it is worse.
Old 04-02-2011, 01:38 PM
froggy47
froggy47's Avatar
Here's a thread I started a while ago when I found play in a rod end.
http://forums.corvetteforum.com/auto...-end-last.html
You can get fronts (MOOG) from Rock Auto but I could not find QUALITY rears anywhere.
Rears are about an inch longer (on my car).
I talked with a guy at VBP & he can't get rears either (that are Vette specific).
He suggested BS kit.
I am going to go with Baer bump steer kit.
You might be able to make your own from parts from a company like Aurora or Midwest.
http://www.midwestcontrol.com/series.php?id=180
Old 04-02-2011, 02:00 PM
davidfarmer
Is the BS kit (Baer zip) long/deep enough for front and rear? I'm just considering it since the moogs cost as much as the BS
Old 04-02-2011, 04:18 PM
Timz06
Timz06's Avatar
I bought some heavy duty rears from Ecklers. It took them about 1 month to send them, I wasn't really happy about that, and they didn't answer any of my emails for several weeks.
In any case, I just installed one, it is about 3/8 " longer than the stock tie rod end. They have zerk fittings and come with a castle nut with a cotter pin.
Part # was 39964 $44.99
Tim
Old 04-02-2011, 09:37 PM
sperkins
sperkins's Avatar
Speaking of bump steer David - how bad is it on a stock C5 at the factory ride height?
Old 04-02-2011, 09:43 PM
varkwso
varkwso's Avatar
I have been buying them used from Vettenuts...
Old 04-03-2011, 02:17 PM
froggy47
froggy47's Avatar
The guy at VBP (I wish I could remember his name, he was a senior guy, like owner or partner) said it's a good kit. Front is different from back (as to overall length) as I said stock back end is longer by an inch.
It's a different part front & rear (I think) as are the oem ones.
Of course the "height" of the pin is adjustable with shims to get the alignment back to level for lowered cars.
I have not got one yet so this is all from description.
If you search the forum you may get a hit on someone who has installed them.
http://www.jegs.com/i/Baer-Brake/136...oductId=759921
I would call Baer direct & talk to them.
Old 04-03-2011, 06:01 PM
Joe_Knesek
Joe_Knesek's Avatar
Speedway Motors
http://www.speedwaymotors.com/search-heim.html
Old 04-04-2011, 09:59 AM
Zenak
Terminal Vette Addict
Zenak's Avatar
Did you read the section here on tie rod ends?
http://forums.corvetteforum.com/auto...e-learned.html
Old 04-04-2011, 10:07 AM
John Shiels
As for the tie rod ends for front (http://www.vbandp.com/SearchResult.aspx?CategoryID=396) and rear (http://www.vbandp.com/SearchResult.aspx?CategoryID=397), you can not go wrong with the Vette Brake Products (VBP) heavy duty units. Make sure you also order the polycovers for them (2 sets for full car) which will keep crap out of them and make them last longer / also resist heat better to avoid dry rot from heat/oil. Since the ends are stiffer they will also hold your track camber/toes setting better & have a limited lifetime guarentee! I used a speed clip for the special nuts the tie rod ends came with, and not a cotter pin. So if I need to get in and out of them later its easier. Oh yeah, its got its own nut and the OEM will not work.
The link does not work. What is a poly cover for a tie rod end? How does heat and oil make dry rot?
Old 04-04-2011, 10:25 AM
travisnd
travisnd's Avatar
Tim
That sounds just like the VB&P rod ends I purchased years ago for my old Z06 and at that price. I checked recently and VB&P seems to have trippled the price on the HD rod ends.
How are you guys checking for play in the fronts? When I grab my wheel at 3 and 9 and try and move it laterally I can see my steering wheel turning a smidge... so any perceived "play" is really me moving the steering system.
The rears are fixed so if you have movement then you know you have wear. So far I've never had issues with the stockers so long as you wrap them with DEI cool-tape.
The BS kit looks like a good option given the price of replacements these days.
Old 04-04-2011, 12:41 PM
sperkins
sperkins's Avatar
Seriously man. Some folks like to ask questions.
You've posted that link 5 times today alone - before noon.
Old 04-04-2011, 01:17 PM
travisnd
travisnd's Avatar
Energy suspension makes a poly balljoint boot for our cars.... they're made for C4s, but work fine for C5s and C6s. Come in handy if you booger up a boot and don't want to buy a new balljoint (I think they make them for rod ends too).
I got in a jamb and had to use a pickle-fork on my RR and cut the boot. Used one of these and it worked great... I still wrapped it in DEI cool-tape to keep the heat off of it, but it's a good bit more robust than the OEM boot.
I purchased them from Summit.
Old 04-04-2011, 01:19 PM
travisnd
travisnd's Avatar
+1
Zenak how can we take your post serioulsy when you have no information on the most important safety upgrade ever.... titanium lugnuts.
To Tie Rod end options...... bump steer kit??
Old 04-04-2011, 02:20 PM
davidfarmer
Going with the ZIP bump steer kit. I have a set of the Energy boots, but am afraid the rod ends are beyond salvage at this point. The BS kit is about the same as 2 moog rod ends, so it seems like a no brainer. I'm not planning on doing a full BS assessment on the car, just set them near stock, although that would be a great project for another day.
I'll post info on the install once they show up.
Old 04-04-2011, 02:22 PM
John Shiels
I know I bought them 9 years ago. Why would anyone need them for new tie rod ends?
Old 04-04-2011, 02:24 PM
John Shiels
+1
and many things when asked are linked to that post that are inaccurate for newbies to read. Before someone makes a post like that they need to be an authority on race cars like Lou G. or the likes.
Quick Reply: Tie Rod end options...... bump steer kit??
