Race car interior/cage painting questions...
Old 04-04-2011, 02:17 PM
travisnd
travisnd's Avatar
Default Race car interior/cage painting questions...
Looking for a durable/simple solution to paint my interior and cage gloss white. What works best?
1. Rattle-can using one of the "tougher" brands
2. Traditional base/clear out of a gun
3. Single stage out of a gun
4. Other
I'm considering using a spray gun and laying down some basic primer and then single-stage gloss white.
I'll probably wipe everything down with prep-solve and give the painted areas of the chassis a light scuff-sand.
Any issues getting paint to stick the the composite tub or anything? Any tips/tricks?
The roof will be off my car so it should be a fairly straight forward job. I plan on paiting the underside of the roof panel and the insides fo the door shells too.
Old 04-04-2011, 02:28 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
If you do with a can it will always be easy to repair.
Old 04-04-2011, 02:32 PM
travisnd
travisnd's Avatar
That is true... but I'd like it to be robust. I could always do touch-ups with a rattle-can if needed.
Old 04-04-2011, 02:43 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Whatever your cage builder charges you to paint the cage, it's worth it.
Old 04-04-2011, 02:51 PM
travisnd
travisnd's Avatar
How much did you guys pay? You guys just had the cage metal itself done in satin black right?
Old 04-04-2011, 02:59 PM
wallyman424
wallyman424's Avatar
I know some subaru guys that have brushed POR15 on their cages with great success. Since its so thick, it finishes out flat and glossy and you can't really see the brush strokes. Can't imagine anything this side of rhinoliner being better than POR15.
Old 04-04-2011, 03:10 PM
John Shiels
Now that is some real tough stuff I love all their products and my garage is full of them. Some vendors charge 1200 to paint a cage when being installed.
Old 04-04-2011, 03:11 PM
travisnd
travisnd's Avatar
Just checked POR 15 doesn't come in white Always wanted my race car to have white guts.
Old 04-04-2011, 03:40 PM
Falcon
Falcon's Avatar
While white is attractive, it will get dirty. I painted my floorpan and such a light gray, and it still shows a lot of dirt.
Old 04-04-2011, 03:46 PM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
rattle can flat black, no glare, hides dirt, easily touched up
Old 04-04-2011, 03:49 PM
travisnd
travisnd's Avatar
I was thinking about just painting the door shells, inside of roof, trans tubnnel, and the cage itself. Would probably leave the stock floor and the rear tub alone the more I think about it.
Old 04-04-2011, 03:52 PM
John Shiels
rustoleum is fair tough after it hardens a week. 6 cans for primer and paint and your done. If you are painting the whole car interior a gun would be better with Imron but you need good air system to feed a helmet or you die!
John Shiels
Old 04-04-2011, 04:11 PM
ScaryFast
ScaryFast's Avatar
I did all this work and used automotive exterior paint plus a clear coat, even baked it in a paint oven...it looked awesome until I used it once.
Just make sure you cover all bare metal so it doesn't rust and don't worry about it. It looks like crap in less than a season.
Old 04-04-2011, 04:15 PM
travisnd
travisnd's Avatar
So KISS.... check Leaning toward gloss white rattle-can on select areas.
Old 04-04-2011, 04:19 PM
drivinhard
drivinhard's Avatar
Bingo!
Old 04-04-2011, 04:40 PM
gmccreary
gmccreary's Avatar
Paint it brown in case you scare yourself
To Race car interior/cage painting questions...
Old 04-04-2011, 04:41 PM
travisnd
travisnd's Avatar
That'd be for the custom seat cover
Old 04-04-2011, 05:16 PM
Kubs
Kubs's Avatar
Received 1,719 Likes on 929 Posts
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I plan on doing mine flat black with no primer. The paint will stick fine to any surface that has been sanded or scuffed. Its not a show car, why worry about a smooth finish or fixing imperfections. Two simple coats of just color will be fine, primer is just adding work.
Old 04-04-2011, 05:42 PM
travisnd
travisnd's Avatar
^ I figured primer would help the paint stick better and hold up better?
Quick Reply: Race car interior/cage painting questions...
