C4 2-piece rotors
Old 04-04-2011, 06:24 PM
Rag Top
Rag Top's Avatar
Default C4 2-piece rotors
Anyone using them with J55/GS calipers for autocross and/or HPDE?
I have only found Baer and Wilwood. Is one better than the other? Are they worth it? Do they hold up to racing?
I am looking for rotors for my C4, with '96 GS calipers. (no- I cannot upgrade calipers or go to a larger rotor. I race NCCC, so changing those items is a no-no)
thanks-
Old 04-04-2011, 07:01 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
Wilwood stuff is good not sure on the others. Are they worth it depends on your pocket you want to let lose. Doubt they will do a hell of a lot in AX. My Stoptech 2 pc are 1 lb heavier than OEM but they last longer as there is more meat on the rotor ring.
Old 04-04-2011, 08:05 PM
John B
Pro Mechanic
John B's Avatar
I thought NCCC finally dropped the stock brake rule. I raced group 3 C4 unlimited engine mods, unlimited tires stock Brakes!!!!
Old 04-05-2011, 12:10 AM
Rag Top
Rag Top's Avatar
Nope, NCCC rules have not changed much. You can run ss lines; air ducts; slotted, dimpled, and/or drilled rotors; and a bias spring in Group 2. Heck, running the GS calipers is enough to put you in Group 2, even if you had J55 to begin with.
To C4 2-piece rotors
Quick Reply: C4 2-piece rotors
