Anyone ever have a K&N-type (cotton-gauze media) filter get contaminated?
I purchased a beat up Haltech off of the forum awhile back for stupid cheap ($40 cheap). It was nasty and in need of a good cleaning. I finally put it on my car (running smaller tires freed up mod points) and it keeps dripping filter oil to the point I have red drops under the car.
I've been using K&Ns for years so I know how to clean them and how much oil to apply etc. I cleaned the filter with the K&N specific cleaner 3x, let air dry over night, then oiled as I normally do. Let the filter sit on the work bench another evening and installed.
Next few days I see the mess and clean it all up.... took the intake off ofthe car and set it on the bench and took a shop towel and screw driver and soaked up any excess oil in the pleats. I ran it at VIR a few weeks back w/o issue.
Well this weekend I noticed a few more red drops under the car and sure enough it's K&N oil.... All I can think is that the filter got enough oil/grease/etc. on it that the fibers simply won't absorb/hold the oil and that it'll just slowly continue to seep off the filter?
Anyone ever see anything like this happen? I can see the top part of the filter pleats getting lighter as the oil slowly migrates down the filter to the lower end.
The oil is collecting at the lowest point & if this is one of those round filters, the low point is the drip point. On the rectangle filters the low point is spread out across the filter.
As long as the maf wire is ok, I don't think it's a big deal, eventually it'll stop dripping.
Can you twist it so bottom becomes top & excess oil redistributes?
It's a Halltech filter... not a drop-in panel filter. I'm not sure sure it'll stop dripping... I've had these filters on C5s for nearly a decade and they've never dripped oil like this. I didn't over-oil it.... oiled it like I've done for years.
Oil evaporates it may take a while.
When I do my K&N I let it dry in the sun after I wash it & then I "dust" it with K&N oil and let it sit a day.
On top of some newspaper & flat
The red K&N oil is very light oil & should evap pretty good.
I still say put a rag under it & give it time. Maybe a little pool of oil is finding a spot to accumulate in the filter? I never had one so not sure of the structure. Is it in an air box like stock or just out in the open?
http://www.halltechsystems.com/product_p/v2026.htm
Wow they have a bunch of filters.
