can't shift at the redline
St. Jude Donor '06
new spec clutch holds fine ,but you can't change gears when the engine is wound up,will go to neutral,then in to the next gear after the rpm drops way down...they say air in the line,,there ain't air in the line..now what??
Johnny
Johnny
Former Vendor
Very common problem that we designed our Adjustable Master Cylinder Kit to fix. Read our FAQ here for more information: http://www.tick-performance.com/tick...aulics/#master
St. Jude Donor '06
Classic case of crappy Spec design/quality. You need an adjustable Tick clutch master cyl. Would have been nice if you would have known that before huh?
I know when I dropped a thousand bucks on my Spec that I was not expecting to spend another three hundred to make it work properly.
Wow. I may have been suffering from this issue since 2006 and not even known this was the cause.
Spec clutch, never been able to shift from 2nd to 3rd at full throttle.
Heck I had my transmission rebuilt in pursuit of a solution.
Pro Mechanic
St. Jude Donor '06
my RPS clutch had given up and I got in a hurry so i ordered the spec..now I have ordered the tick master..lesson learned...when this one has to come out I'll go back to the rps that has since been rebuilt...
Johnny
Johnny
What clutches (other than the tiltons/quartermasters) have you guys had good luck with? I have a new spec, engagement is a little low (properly measured the distances during install per the spec video), hoping the high-rpm shifts are ok this weekend.
Be prepared to have to put in a new clutch MC. You'll likely have trouble shhifting at high rpm, just don't destroy your tranny because of it.
St. Jude Donor '06
johnny
