Before and after...
Old 04-06-2011, 01:56 PM
travisnd
travisnd's Avatar
Default Before and after...
Going through some build pics and found this before picture...
vs. how it ended up as of last night...
Much better
Old 04-06-2011, 02:03 PM
wallyman424
wallyman424's Avatar
Wanna do mine? I've still got the heater core and blower in there.
Old 04-06-2011, 02:09 PM
travisnd
travisnd's Avatar
I only have enough OCDness to do one Getting all that foam off the wires and re-taping them and re-routing anything non-essential made a huge difference.
If I knew anything about EE I'd have started cutting, but then I'd probably open Pandora's box of electrical gremlins.
The HVAC box and dash are very heavy... I had cut much off of the dash earlier in my build and had the heater core and evap unit out of the HVAC box... I had it in place as a blower motor only. Even with the trimming they were still heavy taking them out.
Old 04-06-2011, 02:35 PM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
HVAC is a serious PITA. Sawzall, cut-off wheel, and BFH only make it possible, not easy.
Old 04-06-2011, 02:45 PM
travisnd
travisnd's Avatar
I didn't have to cut or beat anything. For once I read the service manual before I tackled something. It instructs you to remove the blower fan from the assembly first. It's 3 screws and 2 electrical connectors. once that's removed the entire HVAC assembly pulls out... assuming you've already unhooked the AC/coolant lines in the engine bay and removed the 2 bay-side 10mm nuts. All much easier w/ the intake manifold off.
Old 04-06-2011, 02:55 PM
Falcon
Falcon's Avatar
One gains knowledge by reading the instruction manual.
One gains experience by not reading it.
JDIllon
JDIllon's Avatar
Nice job, After you do his you can start on mine! Still not ready to make that move yet. JD
Old 04-06-2011, 02:58 PM
Kubs
Kubs's Avatar
Received 1,754 Likes on 941 Posts
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Looks good! Im in the same boat with my C4
Old 04-06-2011, 03:00 PM
travisnd
travisnd's Avatar
If you follow the service manual too much you'd end up with a really fancy collection of Kent-Moore tools that you don't really need
Old 04-06-2011, 03:01 PM
travisnd
travisnd's Avatar
Nice having so much more room and easy access to everything isn't it
Old 04-06-2011, 03:17 PM
drivinhard
Support Corvetteforum!
drivinhard's Avatar
I still see 50 lbs of unnecessary junk
Old 04-06-2011, 03:24 PM
travisnd
travisnd's Avatar
I'm not done yet... still have a few more tricks up my sleeve
Old 04-06-2011, 05:22 PM
Kubs
Kubs's Avatar
It sure is! I can now get at the clutch safety switch that went bad 3 years ago.
Old 04-06-2011, 08:45 PM
dvandentop
dvandentop's Avatar
any resale for any of that stuff??
Old 04-06-2011, 09:12 PM
Z06Tracker
Z06Tracker's Avatar
Sounds like a man speaking from experience.
Z06Tracker
Z06Tracker's Avatar
Where?
Old 04-06-2011, 09:23 PM
travisnd
travisnd's Avatar
Well I cut up the dash earlier in the build so no on that, I cut open the HVAC box to remove the heater core and evap core, so no on that too. The dual zone climate control works perfectly so that has some value
To Before and after...
Quick Reply: Before and after...
