Spring advice
Old 04-09-2011, 07:39 PM
avizandum
avizandum's Avatar
Default Spring advice
So I was lowering the car (Z51 C6) back to summer weekend warrior height and both front bolts are seized and I need to replace the leaf spring.
Should I go with the Z06 spring or will it throw things off?
Data I saw indicated it's only 5 lbs stiffer.
Old 04-09-2011, 07:42 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
did you unload the spring so that the adjusters can turn freely.......They can seem unbelievably tight if they are loaded against the control arm.
Old 04-10-2011, 09:09 AM
avizandum
avizandum's Avatar
Unfortunately I've done it correctly. I had a brain-child to weld a nut on the top. If that doesn't work, I'm screwed. (I stripped the tops in haste / desperation.)
I'm really pissed, 'cuz had I taken a wire brush to the threads when it got difficult, this probably wouldn't have happened.
Which still begs the question: which spring... It's a DD, so ride degredation is somewhat a consideration, too.
Old 04-10-2011, 12:56 PM
gkmccready
gkmccready's Avatar
I doubt you need a new spring, just figure a way to remove the adjusters and HardbarUSA sells replacements...
Old 04-10-2011, 01:07 PM
drivinhard
drivinhard's Avatar
they are very easy to turn/adjust, even with the car loaded. nice for making adjustments while it's loaded on the scales
Old 04-10-2011, 02:53 PM
sperkins
sperkins's Avatar
I had the exact same problem recently. Tried to weld a nut to it, double nut it and cussed at it a lot - nothing worked.
I had to pull the spring from the car and clamp it in a vise to break it free. They were frozen badly from rust, but I was able to get them out.
Clamp in vise here:
Old 04-10-2011, 04:54 PM
Rag Top
Rag Top's Avatar
Careful with the amount of heat when you weld. You don't want to damage the spring.
Old 04-10-2011, 07:03 PM
avizandum
avizandum's Avatar
Clamp in vise here:
The welded nut worked, but they're still very tough to turn. Did new ones go in OK?
Can new ones be installed w/o removing the springs?
Old 04-10-2011, 10:08 PM
avizandum
avizandum's Avatar
Done...
Old 04-11-2011, 12:38 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
PB Blaster next time and soak it a few days prior. Then never-seize them.
Old 04-11-2011, 09:29 PM
avizandum
avizandum's Avatar
Permatex Anti Seize, or "Never Seez"?
Old 04-12-2011, 07:54 AM
John Shiels
Permatex is fine and what I usually end up with. Aluminum one in silver bottle. It last years on stuff outside.
Old 04-12-2011, 08:39 AM
mfquinn
mfquinn's Avatar
I switched my front spring out and installed the Z06 front. The numbers I have show a difference on 20
FE3/Z51 502 645
FE4/Z06 526 714
To Spring advice
Quick Reply: Spring advice
