AS (AStock) or ASP (Steet Prepared)??
Regarding local autocross using SOLO rules :
Can a stock non-Z51 C5 have the rear sway bar changed to stock Z51
and remain in the AS (A Stock) class, or does that put you into
ASP (A Street Prepared) ?? It is still a stock component, and a Z51 would run in AS.
You can stay in AS only if you change everything else to Z51 also. I believe you could get the Z51 with any option package so you would have to change are the springs and the rear bar (and the rear axle ratio if you don't have that already and you have an automatic). You would also have to add the power steering cooler. Shocks and front bar are free so you can run whatever you want there. As long as you change everything, you can stay in AS.
To remain in a stock class, you couldn't change just the rear sway bar, but the front sway bar is free, so you could do whatever you want with it instead if that would help.
I changed both stock sway bars to C6Z51's from GM Parts House. I had been told that as long as the bars were OEM and a stock option I could replace them booth. But, the SOLO rule book seems to say different.
Although, you know how pissy some club people can be over almost nothing.
Plus, I'm just running for fun anyway, or else I'd go buy $1000 worth of shocks and $1000 worth of tires.
It seems that, you are ALWAYS racing wallets rather than cars no matter where you are on the racing food chain
