Big Bang from rear end, now grinding ????
Old 04-11-2011, 01:28 PM
WNeal
Support Corvetteforum!
WNeal's Avatar
Cruise-In Veteran VII
Cruise-In Veteran VIII
"Slower Azz Dog"
St. Jude Donor '06-'07-'08-'09
Default Big Bang from rear end, now grinding ????
I came in from my last session at Mid Ohio and as I was making a sharp right turn into the garage, I heard a loud bang from the rear of the car.
Pulled it in and then moved it back and forth about 5' or so and was fine.
Pulled straight onto the trailer with no problems. Got home, backed it out of the trailer and then drove it down the street through gears 1-4 and was fine.
Went to turn around in parking lot to back into my garage and loud noise and clunking from rear when I put it in reverse. Pulled forward about a foot and the same thing. Then very very slowly pulled forward and it was fine. Pulled it into the garage where it now sits. Seems to be right rear but not sure
Any ideas on what this could be??
Old 04-11-2011, 01:48 PM
VTME13
VTME13's Avatar
If you still have a parking brake, the stupid shoe spring may have popped out. Happened on mine, and sounded like the diff was shot. Problem is you have to take the freakin' hub out to replace nicely - there is a write-up here with a "zip tie" technique. I couldn't get it to work.
Old 04-11-2011, 01:52 PM
WNeal
WNeal's Avatar
"Slower Azz Dog"
I have removed most the parking brake stuff from both sides of the car but some of the mechanics are still on the right side.
I just took the rotor off and found a part bound up with a lot of damage to the dust shield etc.
That could very well be it and I am certainly hoping so
Old 04-11-2011, 06:02 PM
Z11409
Z11409's Avatar
side gear dropped a tooth
To Big Bang from rear end, now grinding ????
Quick Reply: Big Bang from rear end, now grinding ????
