Got the roof off... don't try this at home...
Old 04-11-2011, 02:17 PM
travisnd
travisnd's Avatar
Default Got the roof off... don't try this at home...
She's a convertible for the time being... The glass guys came over to pull the windshield and rear glass. When they got the glass out I asked them if they had any advice as to which tool I could use to best attack the front and rear roof adhesive. Guys says "hold on".... goes and gets this fancy custom sawzall and gets to work. With my help we had the roof off in 15 minutes. I had already cut the b-billar bar out with my sawzall and cut-off wheel last week. There's no way I'd have been able to cut the adhesive w/o his custom sawzall. Sure I could have used my little cable saw or a heated up utility knife, but it'd have taken all weekend and even then I may have not been able to make a full cut and get the roof free.
To Tim from Custom Auto Glass
Old 04-11-2011, 02:41 PM
fatbillybob
fatbillybob's Avatar
When I took my roof out I left it bolt in for future access. So far it really helps out.
Old 04-11-2011, 02:43 PM
travisnd
travisnd's Avatar
Yep I'm doing the same... will clean off all the OEM adhesive and run some weather stripping in place. I left all the bolt holes in the roof and plan on keeping them there.
Old 04-11-2011, 02:46 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
never seen anything like that before.....at least not in a few days.....
Old 04-11-2011, 02:47 PM
travisnd
travisnd's Avatar
Corvcamino
Old 04-11-2011, 02:50 PM
davidfarmer
after a bit of cleanup...
Old 04-11-2011, 02:52 PM
travisnd
travisnd's Avatar
That's awesome. I'm half tempted to fab up something similar to close the area that would normally be filled by the stock tonneau cover. Then I could take the roof off and have a convertible when I wanted
Old 04-11-2011, 08:33 PM
RaleighSS
RaleighSS's Avatar
Ok maybe a silly question but honest :-) Why you cutting the roof off ?
Old 04-11-2011, 09:40 PM
travisnd
travisnd's Avatar
I'm 6'4" 240 so your typical C5 cage doesn't work for me. Roof off allows the main hoop to take the place of the factory halo and make the cage as roomy as possible. Plus it makes the cage builder's job a good deal easier.
Old 04-11-2011, 10:20 PM
RaleighSS
RaleighSS's Avatar
ahhh ok never thought about that .... good to know
Old 04-11-2011, 10:25 PM
davidfarmer
he is right about that. I never had a car that my head didn't tilt to one side because it was resting against a bar. While the OEM roof would have fit over my main hoop, it was tucked up much higher, and my side bars swing out much wider. Combined with a Kirkey seat sitting on the floor, I'm nowhere near the bars.
In my case, the car was a coupe, and the rear hatch and glass weighed a ton. I had planned on putting it back on until I realized how much weight I could save.
AND I Prefer "El-Corvette-Amino Convertible"
To Got the roof off... don't try this at home...
Quick Reply: Got the roof off... don't try this at home...
