removing hubs???
Old 04-11-2011, 09:03 PM
Rob P
Rob P's Avatar
Default removing hubs???
I am replacing my hubs with the SKF hubs. Having a hard time with the third torx screw on the hub. Is the only way to pop the knuckle out?
Falcon
Falcon's Avatar
Yep!
Old 04-11-2011, 09:05 PM
Rob P
Rob P's Avatar
someone told me of a way with a 2X4 and a hammer.
Any pics of placement?
Old 04-11-2011, 09:51 PM
travisnd
travisnd's Avatar
If it's never been apart that probably won't work... it's never worked for me on the first go. Once they've been apart once it will work.
Old 04-11-2011, 09:54 PM
VetteDrmr
VetteDrmr's Avatar
Received 1,398 Likes on 749 Posts
Go to Autozone, check out their pitman puller, use that to put some load on the ball joint stud, then hit it with a hammer. That's worked every time for me.
HTH, and have a good one,
Mike
Old 04-11-2011, 10:09 PM
JDIllon
JDIllon's Avatar
Maybe this will help! http://forums.corvetteforum.com/auto...-tutorial.html JD
Old 04-11-2011, 10:12 PM
Falcon
Falcon's Avatar
Remove the nut from the lower ball joint.
Put a floor jack under rim of the hub. Jack it up a bit so that some load is on the jack pad. Hit the lower control arm where the ball joint bolt goes through it with a 3# hammer.
It will pop loose very easily.
Old 04-11-2011, 10:36 PM
sperkins
sperkins's Avatar
I just loosen the nut, leave a few threads holding and smack the nut with a 5lb hammer.
Old 04-11-2011, 10:40 PM
davidfarmer
Support Corvetteforum!
davidfarmer's Avatar
as sperkins says, hit the NUT not the bolt (ball joint) or you'll damage the threads.
Old 04-12-2011, 10:46 AM
Rob P
Rob P's Avatar
Are you smacking the hammer on a 2X4 or directly on the LCA?
Old 04-12-2011, 11:02 AM
VetteDrmr
VetteDrmr's Avatar
Directly on the nut; if you use a piece of wood you'll soften the shock wave the hammer sends through the ball joint stud.
Old 04-12-2011, 08:54 PM
Rob P
Rob P's Avatar
Thank you everyone for the quick feedback. I bought a 3lbs small grip hammer and will try to knock it out tomorrow. Too tired today.
To removing hubs???
Quick Reply: removing hubs???
