High heat powder coating Kooks 2" race headers & Pfadt oil cooler kit install
Old 04-13-2011, 06:43 AM
Allthrottleandsomebottle
Support Corvetteforum!
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Default High heat powder coating Kooks 2" race headers & Pfadt oil cooler kit install
FWIW, here is a link to the install threads:
http://forums.corvetteforum.com/c5-t...t-install.html
http://forums.corvetteforum.com/c5-t...e-headers.html
I just got it back up and running Sunday
30+degrees cooler on the oil
If you have a part time play car and can find a used oil cooler its worth it. Ya just gotta be carefull of no front impacts
And I put the OEM catback off the 2000 coupe on for the stealth look and sound just for S & Gs ....................
Did not notice power loss............time for the strip/track after a tune tweak
Old 04-17-2011, 10:23 PM
Cruise-In V Veteran
NCM Ambassador
And this is what it sounds like............
Quick Reply: High heat powder coating Kooks 2" race headers & Pfadt oil cooler kit install
