Question for those who have installed the ATI quick release steering wheel kit
Old 04-16-2011, 08:11 AM
jsottile
jsottile's Avatar
Default Question for those who have installed the ATI quick release steering wheel kit
Did you have to remove the SIR coil?
Does anything else have to be moved once the steering wheel and airbag are removed?
Regarding the torque value of the spline nut, the GM service manual says 30ft lbs, the grant instructions included with the kit says 5ft lbs with locktite. I am assuming I will go with the Grant torque value but wanted to see what you guys did.
Old 04-17-2011, 03:57 PM
RAFTRACER
RAFTRACER's Avatar
Yes the SIR coil needs to be removed and the horn contact tower on the turn signal cancelling cam also needs to be removed..
Old 04-17-2011, 05:43 PM
sperkins
sperkins's Avatar
I did 5lbs per the Grant instructions. It's not coming off.
To Question for those who have installed the ATI quick release steering wheel kit
Quick Reply: Question for those who have installed the ATI quick release steering wheel kit
