Anyone make their own brake duct spindles?
I was going to make some, since 300$ for tube is not for me. What have you used to mount to the hub?
Some products are crazy expensive for what they are. Ducts are very simple to make. Use flat steel or aluminum and a piece of 3" exhaust tube. Total cost is very low. Pix:
Location: Arlington Texas, originally from San Angelo, TX
I bought the quantum spindle ducts, and modified C6 Z06 ducts for extensions, and bought some hose off of ebay, and spent less than half of what I could have spent otherwise. On a side note, if you need some of the 3 inch high temp hose, let me know, and I can sell you a piece.
I made my own. I mounted them to a piece of aluminum bar and tapped the two holes on the spindle to mount the bar too. They work great. I cut off the ABS mount and moved it to the location you see in the pictures. Total cost about $10.
I purchased the Quantum spindle ducts and then made some adapters that mount to the stock duct. Prior to making these I tried pop riviting the SCAT to the ducts...this worked for a while....but, this soulution is much better.
How much of a difference do you guys notice with these? Ill be going to the track for the first time and wondering if this would be a worth while mod
In my opinion, you do not need them for quite a while. I Time Trial my Z06 without them. I have also run it hard (as in 280+ oil temps) for over 30 minutes and never had brake fade.
If you are W2W racing, then yes. HPDE and paying attention to the car or TT, then no.
If you have good rubber and use your brakes hard, you will destroy them in as few as one session. I have seen the pistons deformed around the pad from heat in one session, on race rubber at Laguna. Sure you can baby them and make them last but who wants to do that?
Thanks alot for the honesty
I put them on hoping to extend the life of my disks....not due to brake fade. They seem to help with this.
Has it helped? Comparing my setup to others with brake ducts, I am not seeing where it has extended the life of the front rotors. I think a true fix to breaking rotors is a two-piece setup.
When people are just starting they tend to use the brakes more and harder as you slow for the corners more. Faster you get the less you use the brakes.
It seems to be helping quite a bit...but, I also swithced from drilled to sloted rotors at about the same time, so I can't give you a conclusive answer
I get about another weekend from my rotors after ducting. I bleed brakes about half as often too. Seems to help. I used C6 ducts, and smaller tubing from Aircraft Spruce. I made the spindle ducts, and found a bolt to hold them to the spindle. There is a spare hole in the spindle. I slit the duct and ran the wheel speed sensor inside the duct, but they seem to work well even with that.
I used the c6 zo6 brake duct extensions (the aftermarket are crazy expensive, get a grip vendors). I used steel exhaust tubing welded to a properly shaped wheel speed sensor bracket and found 15' of 2.5 in high temp hose on ebay for $10 from a race team. I did oval out the exhaust tubing at the rotor side to "direct the air towards the rotor hat/vanes (vains). either way
I didn't even have to take the hub off!!! Works like a charm!
FWIW I didn;t do this untill my 5th year of hpde.
Get a 2 piece rotor like DBA and that made the biggest diffence in my rotor longevity. I was cracking a set of the stock a day/weekend at the track on ht10 pads and that was with driving all over the pits after a session to help cool things down.
